nhoj
Is my F3 different I keep reading everyone saying add 5 qts at change and my manual says 5.9.. Is the difference due to it being an SE auto trans??
BRP restated the oil capacity recomendations to prevent over filling.
Use 5 quarts as your initial fill after thoroughly draining the old oil and changing the filter. Then, warm up the engine properly and check the level again. Some find they have to add more others find the 5 quarts to be sufficient. If you have to add more do it in small increments.
