BertRemington
Verify Kill switch position by operating off and on. Yeah happened to me waiting at an intersection resting my hands on the grips. Cost $50 tow and half-day fault isolation.
How to test brake light switch: push the brake pedal and the brake lamps illuminate. Ignition on or off doesn't matter.
Also push horn button doesn't matter ignition on or off.
(1) is the LCD screen making the usual shift in format when you push the Mode button?
(2) are the various speed/tach indicator lights winking out after the usual time delay?
(3) is the fuel pump going through its usual priming sequence?
Yep. Remove it and charge using a smart charger, not a trickle charger for a day and refit.
Apparently, the battery was bad so I bought and installed new battery and tried to start.
Unfortunately, no difference
Anything else to try?
a new battery?
Have you tried jumping straight to the starter?
Stepping on the brake is not required for the priming sequence or the start sequence on my 2014. I usually stand to the left of my Spyder, wait out the safety prompt, push the mode button and then the start button. Then I put my riding suit on during the warmup idle.
