fencepost
While at Americade this year I went by Pitbull Motorcycle Lifts, and asked why they didn’t have a Spyder on display? They said that they had never had the opportunity to lift one. I told them that it would not be a problem to lift a Spyder and asked if they would like me to bring my wife’s Spyder RT over to try. As you can see by the picture it was not a problem. What I noticed right off the bat is the Spyder was extremely stable on the lift compared to other motorcycle lifts I have used. In fact other than a motorcycle lift table you would be hard pressed to find a better lift. Improved stability is due to the wider support that comes in contact with the frame along with the overall wheel base of the unit itself. Clearance was not a problem, minimum height is 4 ½” and maximum height is 25”. We did bring the lift in under the left side because Barbwire’s Spyder has SPYDERPOP’S Catalytic Converter Shield Set; if you don’t have this on your RT it is a must to manage the heat coming from the Catalytic Converter. I have ordered my lift and can’t wait for it to get here. I spoke to Tony at Pitbull at (731)644-7432 or their website is www.pitbullmotorcyclelifts.com
