Plastic rivets
they are a two piece rivet, pop up the center part with a small screwdriver and then it will be easy to remove, put it back the same way
Cruzr Joe
PLASTIC RIVETS
.......How's this for Help...If you come to SPYDERQUEST at Lake George NY in Sept. .....I'll give you a removal tool for FREE ..... :yes:.......PM me for details .......Mike :thumbup:
Not that hard....
If you notice there is a notch on the inner circle where you can insert a small flat screwdriver and pop the center up. Once it is up you can remove the outer section. When installing them back make sure you put the notch so it is easy to get to....:thumbup:
Yeah I got it off for my oil change but I put it back on after. I know people leave it off I might the next time. Thanks for your help.
