Push to Talk
hognut
I would like to add an air horn to my 2014 RTsm6 but also want to keep the stock horn. I have been trying to find out how the PTT switch is wired. It is not used on my spyder so thought it would be a good horn button. Has anyone used the PTT or know where I can get wiring and pin out information? Thank you for any information.
Gary C
Wiring...
Shop manual has the wiring diagrams for all the models. You should be able to trace them and test it out...:thumbup: online $20.00...(I have the green manual)
Gary C
The PTT button runs to the cluster. If you want to use it you must disconnect it from the cluster. It's a normally open button so the cluster will not know it was disconnected.
I have not taken my left grip apart but it's not hard. I am betting you can cut the wires running to the cluster there and then tap onto those from the button and use it for what you like.
Bob
