Question after installing the drag E position handlebars
So I installed these yesterday. But I have this weird issue. I attached a picture. Basically, it is where the old handlebars were attached.
I do not know how to cover it up. Any ideas? it is the circle with the small stick in the middle.
If you just want to hide it, you could make a cover and bolt it on. Just the two bolts left would hold a cover on just fine. Either get shorter bolts or saw the original bolts off to fit. You could get fancy with it and put chrome acorn head bolts or something like that.
The cover could be made from aluminum, stainless, or any other kind of metal. Polished or painted, your choice. If you are not familiar with metal fabrication or don't have the proper tools, then something like 1/4 inch plastic plate would be OK and is very easy to work. It does not need to be real strong, it only needs to cover the old bolt holes.
Online Metals has the 1/4 plastic plate pieces at very reasonable prices. You can cut that stuff with coping saw, jig saw, or whatever you have.
https://www.onlinemetals.com/en/buy/plastic/0-25-plastic-plate-hdpe-black/pid/21728
