Question for all, and BRP - why is there not a dip stick mark for the correct oil level in a cold Spyder engine?
Yes I know that this post almost 6 months old. But it needs some updates.
About the way you check your Spyder
Engine oil. It is like this. It is the BRP
WAY. It has been discussed for 10 years.
So we have to live with it.
End of Discussion.
Have a Blessed Day and Stay Healthy.
Why do they not make a mark on the oil dip stick or make a range that shows the correct oil level while the spyder is cold and sitting level. Instead you have to run down the road for ten minutes, then park it on a level surface and read the dip stick within two minutes? I just don’t get the concept. I am serious from a new 2026 spyder owner.
This is not a "question for all", I don't think. It's a question for you to answer yourself once you have read and decided to comply with the Owner's manual. If you plan on questioning every design decision made by Rotax (NOT BRP) that doesn't fit your personal paradigm of how engines should be designed, you're not going to be able to appreciate the beauty of this engine for what it is.
