tatt2r
PhotoShop Master
so...this topic has come up many times ... i had update done on brakes and because i had over 6000 miles on spyder BRP would cover them ...no big deal ... but they squeeked more after than they did before i ask mechanic that did the job if he used brake quiet on pads he said no ...so rather than dropping bike off i did it myself and i must say it had to be easiest brake job i've ever done ... it seemed after i had brakes done the rear pad were sticking slightly ... i could hear them if i rolled bike backwards by hand ... so i put caliper lube in the bolt that the rear pads slide on and brake quiet on back of pads ...been 3 days and no more squeek or sticking .... also put brake quiet on back of front pads worked like a charm.... i'm sure over time it might start again but so far so good ...
be careful not to brake clips that hold front pads in calipers .. i didnt but i could see if forced you could...
	 :bowdown:
:bowdown:
