raw design power puc?
It's 9 on each spoke. I had to cut the middle lights to a 3 led design to make it all work better. I'm glad I did. It looks a whole lot cleaner and smoother. Just start at the edge and count down....if you do, you'll notice that you count 6 leds before hitting the middle, then in the middle you'll count 3 leds, then as you continue on you'll count 6 leds again.....giving you 2 6's and 1 3's down each spoke.
Hope you have a way to turn them off. Red wheel lights aren't always legal.
This design is called "fire power". It's not red during rotation, it has a deep golden-orange fire effect when riding. So I should be ok. Also, I do have them on a switch, so even while riding, just a flick of a button, and they're off in the blink of an eye.
WHEN U SOLDER WIRES FOR leds what size wire did you use?
Used the wire attached to the lights, and used a small heat shrink to go over the solder point. Got a very small rison core solder and small solder gun from a hardware store. It makes it MUCH EASIER since wire is so tiny.
did u clean rims with something besides rubbing alcohol? do I need adhesion promoter or something else to make less stick to chrome wheels
I used lacquer thinner to clean mine (although I would not do that on chrome rims). Adhesion promoter does give the 3M tape a stronger stick. Valleyspyder suggested to super glue them on. LOL
