Yeah I hear ya. But after the run the rear spacing is ok but the front has walked out. How do I stop that?
Just to clarify- after the short run straight ahead and stop- is the belt on the rear 1-2 mm from the inside flange or is the gap larger?
I reckon you're over-thinking the issue. I have never heard of this same concern previously.
Apply a couple of tiny dabs of grease to the edge of the belt perhaps and take it for a run and see what develops - that's what I would do, but you're not me. :roflblack:
I am with Ron on this one, you're running your belt too much to the center of the rear sprocket; get it to within the 2mm that your book tells ya, and see how it's riding up front. I am thinking you'll be fine then!
I know I will catch it from all sides here so I'll duck and cover after I hit Post.
Maybe tweak the engine alignment just a bit.
I hear what you are saying. I manually set up up front, middle and rear a few mil. Rotating by hand. Re-check tension. Run it a bit on the blocks and make the fine adjustments with the adjusters. Get it correct and tighten the axle while while its running. Re cheek positions and tension. All A -OK.
Then a road test, say a 10 minute ride the fronts walked out again and the rear has moved out a bit.
Inspection reveals the belt has walked out in front and binding on the sprocket flange, the is belts getting hot and binding. The rear has also moved left and opened up a little.
Repeated attempts to remedy this have failed. Starts out ok but moves while riding.
Short reply is:
I'm not setting it up to run like that, it occurs after running for a bit.
By you trying to make it ride in the middle of your back sprocket
:dontknow::dontknow: Good grief!! What:dontknow:? Thats what your showing us!
Mikey, Iso is saying that even if he sets up the rear at 1-2mm, the front still rides out and makes strong contact with the outer edge of the front sprocket, resulting in a rubber burning smell and a very hot belt. He is NOT trying to make the belt ride in the middle of the back sprocket.
Pete
Guess you got to see it in real life, because I've seen a couple pictures that looked spot on and should be working! Sorry for trying to make the horse drink! I am done!:cheers:
That's the bit that's frustrating Iso so much Mikey!
AFAI can see, he's setting it up all correct on the rear, no more than 1-2 mm off the inside/RH edge... And those are the pics you've seen, Mikey - which show that he's got it set up right initially!! :thumbup:
Only then, when he actually rides it for 10 minutes or so to check it's all working properly, it's NOT, cos the belt walks out on both sprockets - out to the middle on the rear sprocket; and out so far on the front sprocket that it ends up pressing hard up against the LH flange, so hard that if the flange wasn't there, he's concerned that it'd walk itself right off the sprocket... But cos the flange IS there, the belt's pressing onto that flange SOOO HARD that the belt is heating up too hot to touch and smelling badly like it's burning, which in itself is not good!! :shocked:
So that 1-2 mm you are seeing and thinking of as pics of his END result actually isn't the END result of what he's doing; that's where he STARTS, with the belt in the right place; and then when he rides, the belt walks out... just a little on the rear; but a whole lot and disturbingly so on the front! It's THAT FRONT SPROCKET, where the belt ends up 'pressing very hard up against the LH Flange, heating the belt to near burning and threatening to walk off the sprocket over the flange' that's the issue! Make sense now?? :dontknow:
If the adjusters are not hard against the axle, especially the left one. The axle can shift forward regardless of how tight you get the axle nut. Not saying this is the case. But there is a reason that riding moves the belt position on the pulley.
Just a random thought, there are spacers on the axle, could the one on the left hand side of the sprocket not be seated properly or possibly assembled in reverse??? Again, just a thought. Sounds like you are doing all the right things with the adjusters, time to examine how the relationship of the spacers to the axle are.
Al in Kazoo
Well since we are all in the game to make a guess. Mine is when they installed the new sprocket, a part in the transmission broke and lets the shaft run out of true. Sure would help if you had the specs on the distance from the case to the sprocket. And if the sprocket shaft has excessive play. OK I am done.
