Red Dust of Death Recall???? Front Sprocket Recall - FINALLY....
James Thorne, next time you pull a sprocket / pulley, can you check if Rotax used a wear collar between the pulley and the output shaft bearing inner race.
Typically, manufacturers do not have the gearbox output shaft seal ride directly on the gearbox shaft. Most times a collar is slid over the shaft, sometimes using a small o ring to prevent leaks, that allows the seal to wear into the easily replaced collar.
If there is a collar, one would expect it to be made longer rather than install a washer.
Regardless, the pulley bolt merely keeps it from falling off the shaft. The splines provide the torque interface for motion.
When you pull the sprocket, you can see the face of the shaft seal. Its rubber faced. From the parts breakdown, the bearing is right behind that seal. The sprocket rides against the shoulder on the shaft, it does not touch the seal. Adding a collar will space the sprocket outward by the thickness of the collar. You are correct that the bolt, sprocket, shaft clamping has little to do with torque transfer or to keep the sprocket from moving on the shaft. That is the splines and the new collar will not change the play between the splines and therefore the fretting issue.
A friend in our Battle Born Spyder group just had her F3 in the shop AGAIN for the sprocket fix (first sprocket failed about 2 yrs ago). Now waiting for parts. BRP and Can Am needs to stop making the sprockets out of cheese AND solve this problem quickly, as their reputation for quality and reliability may spread to their other products.
A friend in our Battle Born Spyder group just had her F3 in the shop AGAIN for the sprocket fix (first sprocket failed about 2 yrs ago). Now waiting for parts. BRP and Can Am needs to stop making the sprockets out of cheese AND solve this problem quickly as their reputation for quality and reliability may spread to their other products.
Being from Wisconsin, I resent your cheese remark :) :)
I did not realize that BRP had a reputation for quality and reliability, or integrity for that matter. They really do not have a reputation for solving problems quickly.
Wrong color! Should be cheese! ! ! ! ! :roflblack:
One of my favorite cheeses is blue
AND:
In response to Fritz above about reliability, quality, and integrity -
Just look up D.E.S.S, front sprockets, Kenda tires, switch gear, drain plugs, belt vibration, and I could go on and on. I haven't had all those problems with my :spyder2: but if we took all the forum members who did have reliability, quality, and integrity problems it would be a LARGE percentage.
Not attacking you Fritz... just (re)stating the obvious.
anyone know why the 2014 1330s werent included in this? because they could get away with it? replaced mine last year on my 14 RT SE6 LTD with about 30k its the only thing my extended warranty has covered but ive only got about 35k on mine.
Here are my thoughts about why that is the case. https://www.spyderlovers.com/forums...eir-sprocket&p=1646273&viewfull=1#post1646273
Also this one in the same thread. https://www.spyderlovers.com/forums...eir-sprocket&p=1647288&viewfull=1#post1647288
I'm not so sure about this ...... I've read 99% of the threads / posts about this and I recall someone posting that the last Month of 2014 production had a couple of Red Dust issues ..... and these would be covered by the re-call ..... JMHO .... Mike :thumbup:
I stopped by my local dealer Saturday (happened to be the annual "Block Party at Kent Powersports, San Antonio, TX) and had a chance to talk with the service manager about the front sprocket safety recall. Here's what I learned. My 2015 RT-S will be inspected tomorrow (about 30 minutes). If there is visible excessive wear/damage a new sprocket will be installed as a stop gap while awaiting replacement parts from BRP. According to the manager that can be expected in January some time. Not a very good response by BRP to a federal government recall, but at least this dealership appears to be taking a proactive approach to the problem.
Has anyone else heard anything different? It would be interesting to know.
:chat:... I talked with my Spyder Dealer and learned that they are waiting for some parts to come. No real answers yet about when they will get the parts. Still waiting...👍
The question is, are the current white sprockets available or they back ordered also, pending the final elusive fix???????
I ordered one in July or August (after the announcement of the recall) and received it. Can't say they are available "today' but they have been available post recall announcement for sure.
I got my spyder (2019 Rt Ltd) from the shop with the warranty repair. It snowed last night so no riding today, but It drove off the trailer last night and up into my garage.
Freemont Motorsports in Florence Co.
Dropped off August 13, 2022
Picked up November 10, 2022
My sprocket was a complete failure. Lost all power to the rear wheel as I pulled onto the highway during a multi day ride. Engine Revved, loud noise but no power. I have a stinger trailer so I was able to tow it home from Durango to the shop.
Here's the sprocket. Very small ridges left on the inside. The mechanic was supposed to get pictures of the shaft but forgot. They said it looked fine with no serious wear.
Here's a video of what it sounded like. The bike is in gear, brake is off. Revving gives no power.
Side note - Mechanic received the part last week but when they went to install it, the box actually contained a water pump. So I actually got the part destined for the next guy (Sorry about that) which arrived a few days later. I guess BRP still doesn't have their act in gear.
