Does anyone have good instruction to remove the seat and possible pictures. I ordered a Utopia back rest and Jonn an Bike Solutions LLC is going to install.
Thanks
spyderjr
Ref the details re Seat removal AKSPYDERMAN Stated
-disconnect the shock absorber at the seat
Is this disconnected from under the seat (Top of cable) or where the shock absorber cable goes through the panel near the battery
How is it connected - Screws or nuts and bolts or just a push fit
normal electrical connector etc
Can't quite see due to angle of seat (when trying to look under at both
top and bottom of the cable run)
Any Information/Pictures helpful
Thanks
Eddie Sheppard
Reading
UK
Also, the ABS passenger sensor on the seat is held on by 3 screws ( 30 torx ) remove the sensor from the seat.
The passenger sensor connects to the seat pan with two screws. It plugs in to the Spyder wiring harness via a connector that can usually be accessed by pulling the wire up through the hole in the body panel. If that isn't possible, the panel need to be removed.Ref my ealier post
Very sorry for my mistake
I was after information ref the Sensor under the seat and confused this with the shock absorber
It is with reference to the Cable which connects the seat to the bodywork
Which I understand to be the Passenger ABS sensor ( I Think ?)
Thanks
Eddie Sheppard
Reading
UK
Look at the other end. nojokeY RIDER
IS THE CLIP ON THE RIGHT SIDE OR LEFT SIDE.? MY SPYDER LOOKS LIKE WASHERS
Y RIDER
