eddieshep999
have a Spyder RT-S 2010 Model SES
I fitted the Utopia backrest which is excellent - The only problem is the extra weight allows the seat to drop and is a problem when filling up
also when on my trip to Germany I carried some extra luggage on the rear seat (No not her indoors/Wife)
Every time I wanted to fill up I had to remove the extra luggage again as this allowed the seat to drop
The gas strut is not strong enough to cope with the extra weight but looking under the seat I noticed another Pre-drilled hole on the other side and decided to make a prop to help keep the seat up
I used a Stainless Steel threaded rod 8mm with a 90 degree bend at the top this fixes through the hole - I used a spacer along with S/S washes and
Nuts one being a lock nut
The S/S rod is covered with S/S tube as this looks better, on the bottom is a S/S Threaded connector 8mm into this goes a 8mm bolt holding a rubber
door stop
The door stop fits into a holder on the frame - Because I used a 28mm door stop this wedges into the groove already in the seat when the Prop is not in use, It is held securely and the seat closes as before
I added some photos to try to show the results
I did consider trying to make a Fuel door in the seat but it looked to difficult and may ruin the seat, also this would allow acces to the fuel tank
the only option then would have been ty try and locate a locking fuel cap - I'm not sure one is available for the Spyder RT
Others may be able to answer that one
Spyder – RT-S SES (AUTO 2010 Model)
List of Mods :-
Added Zuno 660 -Garmin kit as supplied on the Spyder RT Limited
Digital Voltmeter and Digital Clock to replace Fuel and Temp gauge – Fuel and Temp now
displayed in Cluster Display
LED Bulbs Reversing Lights,Front position lights
HMT - Brake Light
LED – Running lights
LED - Mud Flap lights
Rear extended Mud Flap
Sport Tall Wide Clear Windshield
Chrome 2011 Front Lower Wind deflecors
Utopia Backrest
S/S Seat Prop
S/S Handlebar Weights
S/S Grills both sides matching
Bottom Panel S/S Protection
S/S stronger Funk Lid brackets
S/S Bracket for RBNS Hood for Zumo 660 GPS + TourTech Lockable Mount
Rubber Tank protector on glove box
Grip Puppies
Power Socket in Switch Cluster and at Rear passenger Handrail
Rear Speaker Switch for passenger On/OFF
Upgraded Front Marine Speakers
Bluetooth On board Radio to Sena SMH10 Headsets
door stop
List of Mods :-
HMT - Brake Light
Utopia Backrest
S/S Seat Prop
Grip Puppies
