ARtraveler
No longer with us - R.I.P. Dwayne
Sorry to hear of your problem. It is sounding like the dealership did something wrong. All advice above good. Let us know what happens. :thumbup:
DO NOT TOUCH ANYTHING. Put the palels - back. Show them No pictures. It is their doing - let them deal with it, and make it right. (YOU NEVER TOUCHED IT !!)
But it looks like he has cleaned the oil off.
:shocked: Yup, that'd do it!!
The head on that loose stud looks pretty much savaged too, I'd guess someone used a power tool on it but didn't seat the driver properly so they 'thought' it was tight when it was really just stripped!Back to the dealer, & just hope it doesn't take too long to get sorted?!?
ray:
ray:
So, to the OP: go to the garage and quietly, persistently, politely, but forcefully, raise Hell. The evidence of your Spyder speaks for itself - someone did not do the proper job re-fastening the pieces. Human error on the part of a mechanic, not physical or product deficiency on the part of the machine. Maybe you'll be lucky like me and be able to point to a work order that establishes when and by whom work was done on the misaligned parts. Give the garage an opportunity to work out a satisfactory solution, but stand your ground if or where necessary. If they're good professionals, they'll make it right and get you happily back on the road. We're all capable of making mistakes; the need is to accept responsibility and then put things right. Good luck. And after that, enjoy your Spyder as it should be.
AH....It looks like the retaining bolts have been mixed up with the engine oil filter....the engine filter bolts are longer than the bolts on the transmission filter....looks like one of the bolts on the trans-filter has (bottomed out from being too long) allowing the O ring & the oil to escape under pressure ... blowing the oil up over the hot exhaust causing the smoke...
Lucky it didn't catch fire......
Another pic from further out showing one of the bolts not in correctly and part of the o-ring poking out.View attachment 155977
