ARtraveler
No longer with us - R.I.P. Dwayne
Snowblowers and "heart attack snow" do not go well together. More power Scotty, seems to help solve the problem.
All this talk of wet snow ------- well it's all turned to rain and lots of for a desert state. I have 4.28" and still coming down hard. Parts of downtown/Truckee river are flooding now ( about 6PM) and this heavy rain is still forecast for a few more hours. I know some of you guys are used to heavy rain like this but we in the desert are not. Evacuations are also taking place. Hope all effected are safe.
And yes------ this "atmospheric river" is causing ::::::::: Kaos
Not kidding - google Snow Blowers and you will find what some have done to fix this ....... they put some stiff rubber on the 3 blades that spin and actually throw the snow out the shute. The rubber is put so it touches the drum ( the rubber quickly wears to fit perfectly ). In the video's they don't clog because there is no build-up between the blades and the drum...... apparently there is a HEAT factor that causes snow to turn to ice and this helps to clog the shute ....... go take a look ......... Mike :thumbup:
What size snowblowers do you have? :dontknow:
I've always had good luck with anything sold by Troy-Bilt. :thumbup:
We've got you blower's little brother: 208cc, and a 24" width.
It doesn't like wet snow at all, but the Missus can make magic happen with it! nojoke
Blower #1:
11 horsepower ( but is less at altitude) and 30" path. Got it at a healthy discount at Lowes as a return. And I know why--- It didn't work well. After adjusting the governor and doing the recently discussed impeller fix----- it works great.
Kaos
.Not kidding - google Snow Blowers and you will find what some have done to fix this ....... they put some stiff rubber on the 3 blades that spin and actually throw the snow out the shute. The rubber is put so it touches the drum ( the rubber quickly wears to fit perfectly ). In the video's they don't clog because there is no build-up between the blades and the drum...... apparently there is a HEAT factor that causes snow to turn to ice and this helps to clog the shute ....... go take a look ......... Mike :thumbup:
