DR Buck
This past weekend we took our new toyhauler on it's maiden trip. Issues associated with getting to and from the campground are covered in another post. This post is to share what I learned about hauling the Spyder. I don't remember where I read it, but I remember someone saying that you couldn't load a Spyder read end in first. Since my toyhauler only has a 10' garage space is valuable and it looked like it would be easier to make use of if I backed the Spyder in. Spinning the read tire is the first thing I noticed while backing up the ramp. Despite the spinning I was able to back it in and get it strapped down OK. I wonder what others use for tie-down point on the Spyder? I went around the read tire and hooked on to the ends of the lower A frames and the pivot point of the swing arms. Everything stayed in place and the Spyder arrived at the campground safely.
hyea:
The came the unloading incident. :gaah: Did you know that the Spyder Pops bump-skid doubles as a landscaping or excavation shovel/plow? :yikes: Yep! I came down the ramp front first and the bump-skid dug a nice ditch in the campground parking spot. The top of the bump-skid was covered with dirt and gravel which was also packed into the gap between it and the bottom of the front of the Spyder. :gaah: No serious damage though. The Spyder itself is OK but it looks like I put some scratches in the bump-skid and took some of the shine off of it.
So the big lesson learned here is Spyders can be loaded either way into a toyhauler, but only come out unharmed rear first. So drive in front end first from now on. :trike:
