Tim Pringle
What is the foam insert in the glove-box used for? There is more room to store items with the foam insert removed. Is the foam inert required to keep the box water tight?
It's to help keep the heat out. You can remove it but it will keep anything in there pretty warm nojoke
Oh, I see. Thanks Lamonster, I didn't think about that. I guess I will put it back in when summer returns.
I know of a couple of phones and cameras that didn't fair well from the heat.The earliest RTs didn't have the foam insert, nor the additional foam beneath and around the glovebox (inside the panels). The first day got my 2011, I took out the insert and it has never been replaced. It does create more room in the glovebox. Whether or not that's a problem, depends on what you carry in the glovebox.
:agree: But it has never harmed my Rx sunglasses, earplugs, gas slips, pad and pencil, anti-fog, and mosquito repellant in the least. Old touring rider's tip...the cell phone always goes in your pocket. If you crash and come off, you can still reach it to phone for help. It may not be as applicable to Spyder's, but it has stuck hard with me.I know of a couple of phones and cameras that didn't fair well from the heat.
nojoke
nojoke
nojoke
I was thinkingWithout it, the box works quite well in keeping my Hot Cocoa ..:roflblack:
And if you believe that I have another story.
It's to keep the engine compartment's heat from getting to whatever is located there...
