Speedy Spyder
In the near future I will need to replace my rear tire, has anybody used the Kumho ECSTA AST on their spdyer? Your thoughts please....
Since you haven't actually purchased one yet ..... imho the money would be better spent on the General Altimax RT 43 in 215/60-15 or the Michelin Primacy ........... Mike :thumbup:In the near future I will need to replace my rear tire, has anybody used the Kumho ECSTA AST on their spdyer? Your thoughts please....
| 23.86 (606) | 25.16 (639) | 1.3 (33) 5.4% |
| 8.86 (225) | 8.46 (215) | -0.39 (-10) -4.4% |
| 74.95 (1903.81) | 79.03 (2007.48) | 4.08 (103.67) 5.4% |
| 4.43 (112.5) | 5.08 (129) | 0.65 (16.5) 14.7% |
| 845.33 (525.26) | 801.67 (498.14) | -43.66 (-27.13) -5.2% |
| 20 mph (32.19 km/h) | 21.09 mph (33.94 km/h) |
| 25 mph (40.23 km/h) | 26.36 mph (42.42 km/h) |
| 30 mph (48.28 km/h) | 31.63 mph (50.91 km/h) |
| 35 mph (56.33 km/h) | 36.91 mph (59.39 km/h) |
| 40 mph (64.37 km/h) | 42.18 mph (67.88 km/h) |
| 45 mph (72.42 km/h) | 47.45 mph (76.36 km/h) |
| 50 mph (80.47 km/h) | 52.72 mph (84.85 km/h) |
| 55 mph (88.51 km/h) | 58 mph (93.33 km/h) |
| 60 mph (96.56 km/h) | 63.27 mph (101.82 km/h) |
| 65 mph (104.61 km/h) | 68.54 mph (110.3 km/h) |
I did did some research:
23.86 (606) 25.16 (639) 1.3 (33) 5.4% 8.86 (225) 8.46 (215) -0.39 (-10) -4.4% 74.95 (1903.81) 79.03 (2007.48) 4.08 (103.67) 5.4% 4.43 (112.5) 5.08 (129) 0.65 (16.5) 14.7% 845.33 (525.26) 801.67 (498.14) -43.66 (-27.13) -5.2%
[TH="class: nobg"][/TH]
[TH="bgcolor: #0075AC"]225/50-15[/TH]
[TH="bgcolor: #0075AC"]215/60-15[/TH]
[TH="bgcolor: #0075AC"]Difference[/TH]
[TH="align: right"]Diameter inches (mm)[/TH]
[TH="align: right"]Width inches (mm)[/TH]
[TH="align: right"]Circum. inches (mm)[/TH]
[TH="align: right"]Sidewall Height inches (mm)[/TH]
[TH="align: right"]Revolutions per mile (km)[/TH]
Speedometer Difference
20 mph (32.19 km/h) 21.09 mph (33.94 km/h) 25 mph (40.23 km/h) 26.36 mph (42.42 km/h) 30 mph (48.28 km/h) 31.63 mph (50.91 km/h) 35 mph (56.33 km/h) 36.91 mph (59.39 km/h) 40 mph (64.37 km/h) 42.18 mph (67.88 km/h) 45 mph (72.42 km/h) 47.45 mph (76.36 km/h) 50 mph (80.47 km/h) 52.72 mph (84.85 km/h) 55 mph (88.51 km/h) 58 mph (93.33 km/h) 60 mph (96.56 km/h) 63.27 mph (101.82 km/h) 65 mph (104.61 km/h) 68.54 mph (110.3 km/h)
[TH="bgcolor: #0075AC"]Speedo Reading[/TH]
[TH="bgcolor: #0075AC"]Actual Speed[/TH]
[TH="align: right"][/TH]
Although I find it odd that the Altimax would wear early with a higher inflation ( you didn't mention what PSI ? ) ...... I'm glad to hear you are trying that Pirelli out .... I think might be a better tire than the Altimax ... I plan to get that for my next rear tire ...... I would try to get it close to 18 psi and see how it handles for you. Have you been on a WET road with it yet ????? ......Thanks , Mike :thumbup:I tried the General but I think I had it over inflated and only got about 8,000 miles. someone on the thread, "you? " informed me on the best psi numbers.
Front Kumo Solus KH16 155/60R 15. Great handling if you are a sport rider. 16 to 18 psi max as they get a little bouncy with more air.
Rear Pirelli P4 P215/ 60 R15. Does everything well. 18 to 22 psi max. At 100 mph on the GPS reads 99 mph on the odometer
About 8,000 miles on this set up and they compare to new. Given my bad driving habits the best tire life and performance so far.
From the perspective of a first spyder owner, who's been looking into replacement rear tires:In the near future I will need to replace my rear tire, has anybody used the Kumho ECSTA AST on their spdyer? Your thoughts please....
:agree::agree::agree: ..........However this is easily remedied by adding a 1/4 " spacer between the fender and it's bracket ....... been there - done that ...... Mike :thumbup:Both the 205/60R15, and the 215/60R15 are popular tire sizes used as replacements. Many to choose from. It has been reported that the 60 series tires correct the spedometer/gps error that exist with the OEM Kenda. The XXX/60R15 tires are both taller(increased sidewall height), and as a result a larger circumference compared to the 225/50R15.
Just a word of caution here; if you have an RS or RSS, (can't speak to the ST series, though I suspect the the results are identical) the 60 series tires do indeed put your speed indicated on your speedometer exactly in line (phase) with your GPS. They fit, but very tight in proximity to the rear fender.. Examine carefully the routing of the license plate light wiring, not much room for error before it rubs on the tire. I have been told that this is not an issue on the RT's. Ask me how I know:yikes::yikes::yikes:
