I have a 2018 F3 limited. The front end scrapes at times going in and out of gas stations, parking lots and some times pull over spots. I know others have experienced similar.
I so far just have the stock tires and shocks on it. The manual says max tire pressure for fronts at 17psi and I have mine cold at 16.5. Can I go higher and would it help the scrape problem?
My other thought was tightening the front shocks a bit? Hubby says it is easy to do but in doing so it could change the alignment?
Just trying to think what may help. BTW my tool kit doesn't have the shock adjuster wrench in it... Did I loose mine or did it not come in the tool kit?
Thanks for the advice
