GRHorst
I have a 2021 Spyder F3L that just turned over 11,000 miles. I bought it new and changed oil at 3K, 7K and now 11K miles. I read that you are OK to go more miles before a change. But two observations:
1) After an oil change the shifting is MUCH smoother and I can also HEAR a difference in the transmission (I am a piano tuner and probably have more sensitivity to sounds and changes in sounds)
2) How does the engine oil and transmission oil mix. I know it's the same oil. But does some find it's way to the tranny side never to return? I pulled the left larger plug first and drained the engine oil. When that slowed down to a drip, I pulled the smaller plug on the right side (which I understand is where the transmission oil accumulates). I'm not sure of what I saw, but the right tranny side oil appeared to be significantly darker in color. I don't think it was my viewing angle or lighting difference. I used the same light under the bike. But this oil certainly appeared to be darker.
So this begs the question. Would it be advisable for more frequent oil changes just for the benefit of the transmission?
