The instrument panel turn signal indicators are impossible to see in the daylight. I've read that a few folks have mounted LEDs elsewhere on the bike, either on the "dashboard" or on the mirrors.
My question is where to tap into the turn signal wires. Turn signals use CANBUS to communicate, sending a message to turn the signal lights on or off as required.
I've heard again and again to not add or subtract anything from CANBUS-controlled circuits.
If I tap into the Left or Right signal wires at the back of the instrument cluster, will CANBUS yell at me? I'm planning on linking an LED to the signal wire, installing the LED in a visible location on the "dashboard" to even with bright sunlight, I can see if the turn signal is on or off. The LED draws close to zero amps/watts/whatever the correct measurement term is.
Your thoughts?
Yes: I searched. Found the very informative primer on CANBUS. Makes me think this is NOT something I can(bus) do. BUT, I sure would like to! the LED's low draw prompts my question.
Your advice/counsel is muchly appreciated.
Your thoughts?
