We Need an Oil Additive Thread
SCWSpyder
Fellow Spiderites! So the video from Petron Plus shows it as the only additive able to prevent the bearing, used by peddler with a beam-type torque wrench, from stalling out the electric drive motor. So isn’t that proof it should make a 1330 Rotax motor last mochos longer, etc? Anyone use this?
If it is the new wonder snake oil, it would be in the owners manual for each car and bike on the planet.
After much searching on places like Bob is the Oil Guy https://www.bobistheoilguy.com I've learned that if you have to add anything to the oil you've purchased an incorrect oil. Besides, if the additive is that slick it will by very nature wipe out the JASO MA rating on the oil and probably make the clutch slip. Just my thoughts...
Good luck with your wet clutch!:yikes:
I've played with a number of oil additives over the years. Oil has gotten much better. If you want to put something in your oil. Save your money and put it towards a better quality oil.
I would never put an additive into a wet clutch application. The best you could hope for would be that nothing went wrong. Not a good bet.
The only additives I've ever known to be of benefit and actually work were a very high detergent additive to quite and loosen a stick lifter; and a very thick as honey oil additive (comes in many brands) that will temporally help a vehicle pass the exhaust smoke test, to in turn pass the actual smog test. That thick stuff helps to keep oil from easily passing by the valve guide seals. All these additives are only a temporary measures to mask issues that need major repair. Engines, transmissions and the like are just like people, they all only last so long.
My buddy back in the late 50s or early 60s added a "miracle" additive on the order of Bardahl or STP to his motorcycle. It took him weeks to get the clutch to quit slipping!
Years ago, when two stroke gearbox oil arrived, it came in various viscosities. My friend decided he liked what he read and put what he thought was 80wt into his Maico 490. What he incorrectly put in the Maico was automotive rear diff GL4 gear oil.
That clutch slipped as no other. Ultimately, even after several gearbox flushes with motor oil, the clutch had to be torn apart and the plates washed in solvent.
Your engine would be fine on cheap engine oil. The gearbox is what destroys oil and sees wear. Sadly though, wet clutches do not like additives, especially Moly.
High quality automotive oils often contain “energy conserving” additives that render the oil too good for wet clutch use.
Actually, there is LUBRICATION and there is SLIPPERYNESS (is that a word?). Though they tend to overlap, they are not really the same thing. You can get good lubrication without being extra slippery. It costs more to achieve this. But it can be done. This is what the JASO rating is all about.
Oil Additives
:coffee: All good Tips. Long story made short, ' Do Not Use any Additives in Spyders'.....:thumbup:
Not sure where you are headed with your comment. I purposely refrained from technical info in my post you quoted. Since you brought up the terms Lubrication and Slipperyness, which you may find is technically lubricity, but I may be wrong on that, and you are an a dealer for Amsoil products, i yield the floor and ask that you explain the subject matter you brought up.
This may or may not be relevant, but I notice the newer model Harley's are using some heavy duty viscosity oil, not sure what's that's all about. Not comparing apples to apples I know, just a passing comment.
That is a myth as well.
Check out Redline oils. Their MC oils have over 400 ppm of Moly.
The solid moly (MOS2) doesn't work in HIGH concentrations, the tri-nuclear version of Moly does.
The only thing in 40 years of playing that I found is of any benefit, (and it is a very small benefit), is Ketjenlube. That ester doesn't cause clutch slip, and works in harmony with ZDDP to minimize wear. Others have stated, just get a decent oil and change it regularly. There are many out there, it is not hard to find one.
Ketjenlube blurb...http://www.italmatch.com/wp-content/uploads/2015/06/Engine_Oils_brochure.pdf
I step away. After reading his post, it seems every oil containing moly is acceptable, he can explain more.
Myself, I will continue using Mobil 1 10w40 Racing motorcycle oil with no additional additives.
I do not even bother playing as you called it with oils or additives any more. My go to reading and source for oil quality is 540rats blog. No more Bob is the oil guy, no more internet forums, pretty much no more manufacturers sale info. I see what 540rat rates the oil at and accept it as accurate. Done.
Nope, don't add that crap. If you use a good quality synthetic oil you can go to the 9,300 oil change interval no problem. Not sure? Do your own oil analysis.
