Huddleston
I have a 2013 RTS SE5.  I have done the Kewl Metal Air Filter, but use a paper filter instead of the K&N filter.  I have done the Cat Bypass, and kept the stock muffler.  I have replaced the plugs and wires with BajaRon's plugs and wires.  Everything else is stock.  The Spyder is now running great.  My problems with a rough idle are gone.  However, I am still receiving a P1175 code, which indicates a Rich condition on Bank 2 (the back cylinder).  The manual says check the fuel pressure regulator.  On the phone the Spyder mechanic has told me that it is sensing a lean condition, which causes the computer to provide more fuel, hence the rich code.  He thinks I need something like the Juice Box, but everything I read says that as long as I have kept the stock muffler, I should not need it.  If my mods are causing the code, I would expect both banks to report the same code, which it is not.   I have read all kinds of messages about a bad ECM, an emissions valve leak, purge valve, O2 sensor, etc.  I'd like to have a list of things I want the dealer to check when I take it in.  Can someone please tell me what to have him check next?  I would appreciate all suggestions.
