Not sure they could get away with a nylon gear in an aircraft motor. A bit more riding on components in that application. Rare oil pump failure is probably not so acceptable in a plane.
It would be interesting to know, though, what they do use in those engines.
Funny you should say that....
There was a time in the dim dark past where I flew Victa Air-Tourers, which were small, single engined, low winged,
civilian aircraft -
https://en.wikipedia.org/wiki/AESL_Airtourer and their later Aero Engine Service Ltd/Pacific Aerospace Corporation 'Military' version, AESL/PAC CT-4's, which were small, single engined, low winged
military (training) aircraft -
https://en.wikipedia.org/wiki/PAC_CT/4_Airtrainer - both aircraft which were basically originally built by Victa & ultimately used a fair bit for training new pilots, civilian and military...
Mind you, it'll help explain my point if you understand where Victa came from - they originally started out making outdoor garden equipment, including petrol, electric, and battery powered lawn mowers, edgers, trimmers, and chainsaws, before branching out into making aircraft, albeit eventually selling that branch of the business off: Here's some background:
https://en.wikipedia.org/wiki/Victa
However, those of us who flew &/or maintained these Victa Airtourer & CT-4 things found out that there were actually quite
a LOT of nylon gears, bushings, and other sundry parts in these aircraft, some of which
were in 'high wear' areas; and we discovered very quickly that some of the 'nylon' parts used in these aircraft had a tendency to wear out pretty quickly... not to the point of causing aircraft to fall out of the sky without warning, but certainly such that pre-flight checks or maintenance checks often found the nylon parts were worn to an 'imminent failure' degree!
From there, it didn't take too long to work out that sourcing the appropriate 'aircraft' &/or 'mil-spec' spares to replace the worn out parts was often difficult, expensive, &/or they would take quite a while to get in, especially if you needed to get the mil-spec gear!!
And that'd mean there'd often be fairly long periods of time where an otherwise serviceable aircraft would be sitting around waiting for some simple but fairly critical part like a nylon gear, a bushing, or maybe just something simple (but reasonably essential) like the trim-tab detent - but there's a very strong rumour that'll I'll neither confirm nor deny here that if you were truly stuck, you could often just duck down to your local hardware store/lawn mower shop and buy the equivalent 'lawn mower/chainsaw' part (often with the same part number, minus the aircraft/mil-spec identifiers on the end
) and use that to get the aircraft back in the air while you waited for the 'proper spec' item to (eventually) come in...
Not that I would ever be party to something like that, tho...
But I can assure you from first-hand experience that you really shouldn't underestimate how many nylon parts there might be in an aircraft/aircraft engine! I strongly suspect that there's
WAAAAYYY MORE than you'd
ever expect!!
