What mods have you customed designed or re engineered for your spyder?
bluestratos
I know there are lots of custom built or rebuilt mods out there for us project minded spyder riders to work on. I am not speaking of mods out of the box unless it was not intend for this use and you were able to work with it. So while I have a long list of mods, for example I will list some of the ones I built or altered to work:
  1. Small aluminum hanger bracket that clips to dash panel to hold drive grab bag
  2. Driver grap bag modified to hold on with suction cups (use this for the small things like trash, window rag, place to stuff gloves etc)
  3. Aluminum bracket that spring clams on center of dash to intall my video camera or other such equipment
  4. Home made mud flab
So let me see what you have come up with , small or large
Thanks,
Randy
Great idea for a thread.
I am not mechanical, so will sit back and watch what kind of neat stuff is out there. :bbq::bbq::bbq:
Installed weatherproof USB port on dash so I can plug in my Portable GPS, phone, IPod. Also installed mirror mounted turn signal LED's.
It's not nailed in place yet... but I've got a Stebel Nautilus that's gonna need some tinkering to fit! :thumbup:
That's on the pile; after the RonBar and GloRyders
Here's a couple..!!
412000_10151148004642385_1435422581_o.jpg 20130108_113326.jpg 20130108_113301.jpg 20130124_121535.jpg
Luggage rack mounted to back rest, front grille, fog and driving light, switches for light, park brake extension, working on some others will post pics as they are completed.:thumbup:
"custom" ipod holder
Don't want to take all the credit on this one... my idea came from someone else on the forum. I refused to pay some 50 bucks for the BRP ipod holder, so I fabbed my own. I used an old web strap cut to length, removed to 2 screws on the right side of the inner frunk, pushed the screws through the strap, and hung an old blackberry case with belt hook on the strap. Best part, it was totally free as I had all the necessary party collecting dust in the house.
Thanks,
Randy
I was the first to add rubber and suggest that John do the same.
SealFloorboards originaly came with no rubber
I tried many different designs
I was going to ask John to rename them SealTicketfloorBaits, but choose not to pursue.....
I cleaned the back with mud flap to keep trailer clean na fabricated a flag holder for Patriot Guard Missions.
modified my RT muffler to sound like a motorcycle.
[h=2]
RT muffler mod[/h]
Being an ex-harley guy I thought my RT sounded like a well made sewing machine, not acceptable. I took the stock muffler, band sawed it into thirds. Then took a cutting torch and burned EVERYTHING out of it. After welding it back together I took it to the local muffler shop and had them burn a hole in the end, insert a 2 1/4 inch pipe all the way up to the cat connection. welded the pipe securely at the rear of the muffler. I have had it ceramic coated (heat resistant). I did not use the rear cover on the muffler, But I did have the front heat shield coated as well. The sound is great & the look ( with good welding, and the ceramic coating) is quite good I think. get 12 inches past the end of the muffler with the pipe. I have run mine 5k mi since the modification with no temp. problems. no codes thrown. This I believe is because the oxy sensor is in the cat. and not in the muffler.-----Budro
$50.00 muffler bought on line (just in case)
$75.00 cutting & welding
$100.00 at muffler shop
$107.00 coatingGEDC0188.jpg​
Not exactly a big deal, but at least 3 people that have similar trailers wanted info on type and installation of this gas can on my trailer.
Cruzr Joe
Sent by morse code from a hidden bunker
When I first ride my:spyder2: 2012 RT SE5 I found that the brake pedal was to small so I made a mod and
replaced it with a regular automotive disc brake pedal. Sorry I can't find a way to post a picture for everybody
to see. I tried:(.
Sarge707
It's over the plastic. This way the air flow is more direct to the two radiators on either side..:thumbup:
I made my own drink holders out of a bike water bottle holder and a desk pen cup from Walmart.
Passenger Cup Holder
Ignoring general lighting?
Custom fender running/brake lights + turn signals whilst preserving the reflector.
Custom cargo webbing is saddlebag and trunk lids. I think i might have been the first to do this...
Custom dash mount 12V accessory outlet. My console garage door opener might be in here somewhere too.
Battery tender pigtail connection under front hood
