I'm not talking about riding around with a breaker bar, but the socket itself would be great in and when the event happens where you get a flat and a broken bead bombing around on back country two track with the closest Bombi dealer being 200 miles away, with the socket you can get to any Joe's Garage and get your tire repaired.
BRP is advertisng the machine as an offroad vehicle and at the very least IMO BRP should provide or at least offer the socket at a reasonable price for the offroad rider, I know if it was me riding a Ryker offroad I would have the socket just to avoid a blown day driving to a Can Am dealer :cheers:
https://www.youtube.com/watch?v=3w0gKBvXZgs
I have had my 65 mm socket for some time but it occurred to me that it is much more likely that the shop on the road will have a 1/2 drive torque wrench than 3/4. Therefore I had just ordered the 3/4 to 1/2 inch adapter when I saw your post. Timely
That 65mm socket from FleaBay may work but it is definitely not the correct one. If I'm torquing to 215 ft. lbs I definitely want the correct socket. I do think BRP should supply this no charge because no one but a Can Am Dealer will have one if you need a flat fixed. I guess I will bite the bullet and buy one when I pick up my Rally.
Why do you feel the 65mm socket (normally used on some Ford Transit Connect vans) is the incorrect one? There are a wide range of quality in tools but there are some well made ones available. 65mm 12 point socket is a universal size. There is nothing special about the one from BRP other than its from OEM Tool and marked up several times as it passes through the supply chain. Its a quality socket but nothing special.
Poli, I'm not sure if you have tackled the rear wheel yet but it appears the socket will need an extension so that the torque wrench clears the tire. I ordered one of these: https://www.amazon.com/gp/product/B000FP8C78/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1. Not so much with the breaker bar because it can be angled away from the tire. And I have to admit to being a bit of a tool wh..e
Because the one on Fleabay isn't even shaped properly to fit the nut, that's why I think it is incorrect. The one on Fleabay is rounded where the BRP tool is more straight cut and a star pattern. Use what you want. all I'm saying is it isn't the correct one.
I've checked torque on rear wheel. I have a 1/2" torque wrench and with the 1/2 to 3/4 adapter, it works without any extension.
OK guys, this is what you need! After much searching I finally find the ideal unit, a torque multiplier. This unit has a 3.4 to 1 torque ratio with 1/2" drive in and out. Get the nut snugged down, then put the socket on the output drive, your torque wrench on the input side, rest the torque arm on something secure, and tighten away. You can easily put 220 lbf-ft of torque on the nut using only 65 lbf-ft of torque on your wrench. You might even be able to carry the socket, this multiplier, and a 1/2" torque wrench on the Ryker somewhere.
https://www.northerntool.com/shop/tools/product_200712282_200712282
