Where Are Battery Posts on 2012 RT?
I need to jump start my 2012 RT SE5, but the picture in the user's manual does not point out where the battery posts really are! Can someone post a pic, or give me a specific location of the positive battery post? The 2012 RT battery is under the seat, not in the frunk like the 2013's. I can hook the negative cable to the frame as ground, but the positive post location is not "obvious", and I don't want to fry anything. I believe the positive post can be accessed without removing the plastic battery cover, and that would be ideal for a quick jump start!
This is what I found on Youtube.com RT Can-Am Spyder Changing Battery 2010-12 SpyderTV,
Deanna
It is still possible that you have a bad battery. I had a battery go bad after a year although I always used a tender. Much to my astonishment, the tender I was using was for lead acid batteries only and my battery was AGM! So I had unknowingly been shortening the battery life. I had to buy a new tender along with a new battery. My new tender has the circuit to distinguish between a lead acid or AGM battery.
Good point. I'll check my tender and see if it can detect the difference.
Sometimes, the unexplained happens. I’m attempting no guess or explanation. As soon as it’s warm enough, go for a 5 hour ride. Get some BBQ. Warm things up and dry things out. Be careful out there.
I'm thankful for the blessing! I can't even begin to determine why it started easily after refusing to start with the associated issues. I will do that long ride once the weather allows. Maybe a nice ride along the Outer Banks and lunch at the Black Pelican... :doorag: I try to be careful all the time. LOL
