I am a new owner of a 2016 F3 S and am loving the ride. I am trying to understand the quirks real or otherwise. The temperature shows 79° F on starting. Is this a normal experience or is it possible there is a sensor issue? As it is, from a cold start, I cannot believe this is correct. Coolant is full, Oil is correct. I haven't checked the radiator yet, still working on the concept of dissembling and reassembling. Any ideas on the way forward I would be most grateful. :banghead:
If it isn't broken don't try to fix it or you may end up with more expensive issues than you bargained for. These machines are computer operated and basically, smarter than we are. So in short, if you don't have an actual problem with the operation of your scooter, don't mess with it and create one. I'm just speaking from experience here. If you're insistent on knowing the ambient temp, buy a little thermometer with a suction cup and stick it somewhere on your spyder. Good luck and stay safe.
