Will Sling-Mods Steering Damper make my Ryker's steering in general more difficult? How hard is it to install?
dryadsdad
I've recently purchased a 2023 Ryker Sport. We have uneven roads here, many of which are cambered. I've found the steering on the trike to be twitchy and in some instances scary. By that, I mean that sometimes I've hit a bump and the trike bump steered me toward oncoming traffic. This has resulted in me being constantly tense while riding, the polar opposite of what I'd hoped for in my motorcycle substitution purchase.
I note a steering damper offered on Sling-Mods' site. I expect this will reduce the bump steering but will it make steering in general, such as negotiating a road curve, more difficult? I'm at best a wholly untalented mechanic. Would such a cloddish fellow like me have a chance to get this installed properly?
Any other comments welcome.
I'll likely be purchasing a Ryker before next riding season. Two things will be installed immediately: BR sway bar/links; and a steering stabilizer.
It sounds like you are new to three wheelers.
Rykers take a while to get used to, give it a while.
A relaxed grip on the bars helps.
I do have a damper on mine and it does help with bumps and holes.
Steering effort might be a little more, but it's not bad. (Mine is set on 5 or 6 and I have a bad right arm.)
Go though some of the older threads and you will find a lot of people had the same problem (me included) at first.
Hope this helps.
Bruce/Raven
Fitted one onto my Rally, it's set to 6/10 on the clicker and works exceptionally well. Easy to install, an essential add on in my opinion... plus the swaybar upgrade.
Hope this helps.
Bruce/Raven
I am new, only hours into ownership.
OK, it turned out there was a difficulty right from the dealer. A friend of mine who's been a Can-Am rider for years (both of us two wheel refugees) suggested that my tire inflation was wrong. I checked, finding all were over-inflated, the right tire dramatically so! So I corrected that and will head out this AM soon to see if that helps.
I kept telling myself to relax my grip, but it was difficult when a bump would change my heading onto a Ford F350 coming at me from the other lane. I'm hoping for a mellower ride today, so that I can lessen my grip to where it should be.
I'm just back from another ride. I'm beginning to wonder if my bike days are behind me.
Don't give up yet! The steering damper does help the darting about feel, even more will a proper sway bar. And time. 1000 miles or so to learn how to relax the grip and stop fighting the bike. Most people wonder if they haven't made a giant costly mistake until time and miles change that.
I'm going to hold on for sure. I'm just feeling a bit discouraged about it.
I was the same as you for a while... at least privately. It's a difficult transition moving from two to three wheels, but better than skipping to four. As for my 2cents... most of the sphincter moments will be at pace, so keep it way slow until you figure it out a bit more. For example, my cornering improved when I learned to slow down into them and accelerate out of them; I figured out you can't just jump onto three wheels from two wheels and try and keep the same pace, it's a whole new learning curve.
Rykers need a bit of set-up (most of my bikes did as well), especially if you ride at any pace. The Steering dampener and swaybar being the first bits. Stick with it, I'm glad I did... In my case my only other option was a convertible. :p
I haven't given up and don't plan to unless I despair. I agree that taking corners at speed now is uncomfortable but then again, I can't usually slow down all that much because I'd inconvenience traffic behind me.
It'll be one step ahead of the other. Based on my slight experience plus many posts such as your own, I'm disappointed in Can-Am for not fitting an OEM steering dampener.
I came from close to 60 years of riding two wheels when I had to quit.
Take a three wheel riding course if you can, it helps.
Find some back roads with little traffic to ride on for a while.
There were some back roads around here I could rail at over the speed limit on two wheels. But on the Ryker I was white knuckling at 40mph.
Three wheels takes some getting used to because you have three tracks to watch for. ( car- two, motorcycle - one)
A crowned road will pitch you around, but you are still going straight.
Just take it slow, don't let anyone force you into going faster than you feel comfortable.
If they want to pass let them.
Take your time, it will come.
We have all been there.
Bruce/Raven
I know just how you feel. I was absolutely bug-eyed after my first ride on my Ryker Sport, had my husband give it a try and he came back pale as a ghost. I thought I'd made a horrible mistake by buying the bike. For me and my bikes, an upgraded sway bar made all the difference. Scroll to post #25 in this thread, I think you'll be able to relate:
Don't despair, help is on the way.
Sarah
Thanks, Sarah. I'm definitely feeling down about this purchase but also unwilling to give up. I figure I've got nothing to lose by hanging in there but a definite loss by giving up. So far my wife's (a two wheel veteran) hasn't braved the Ryker. I'm curious her take on it when she does develop an interest in trying it. She sold her bike when I was forced to sell mine since she lost her riding companion.
I've had a Ryker since 2019 when they first came out. With so many years on Spyders under my belt, I have not seen a need for a steering damper. I think time in the saddle and experience can nullify much of what initial riders find wrong with the steering. Yes, if you're hitting large potholes at speed, the impact does come up through the handlebars. We tend to compare this to the cars and 2-Wheels we've driven, expecting the same. But it isn't dangerous and, with time, it isn't all that annoying.
It's like belt vibration on the Spyder. If you come from motorcycle that actually vibrated through every contact point, the small amount created by a Spyder in good condition just doesn't seem all that big a deal.
In the end, every product can be improved, depending on what that means to you.
I don't know what type of bike you had before. If you are used to bikes with windshields or fairings, riding one without one can make it feel strange.
None of my bikes ( Well the Honda Interceptor had a quarter fairing) had any type of wind protection.
Most made of mine had you leaning forward ( think early superbike or flattrack bike or enduro) and feet tucked up.
When I first got the Ryker it felt really strange, sitting up with my feet forward and the wind knocking me around.
Putting some unwanted input to the handlebars.
After a few months I put on the small Sport windshield.
I know it sounds like BS, but for me it made a huge difference.
A lot less wind buffeting. I almost got caught speeding a couple of times because it felt like I was going slower.
Also as I said before, find a three wheel riding course.
It will be a BIG help.
Sorry for the long post , hope this helps
Bruce\Raven
Bruce\Raven
It just goes to verify what we all know. Some people want to turn their bike into a climate-controlled cocoon. No wind, no heat, no vibration, no discomfort, automatic transmission, etc.
When I want this experience, I drive my car. But that's just me.
Others, like myself, tend to go to the other extreme. To judge someone for how they set up their ride (other than acknowledging that you wouldn't want it that way) is hypocritical. I'm sure there are many of you out there that wouldn't appreciate the way I have my ride set up.
Should either of us care? Not really. The owner is always the final judge of their ride. You and I want that for ourselves, we should be willing to give it to others.
There are those who will look down on anyone not riding a Harley Davidson, for example. Is that right? No. Should we care? No, we should not. Personally, I much appreciate riders that have a good attitude about how others enjoy riding.
Now when you get to something that is unsafe or unreliable, I may be bolder to say something. And you’ll certainly hear from us if you bring your ride to the shop for service or installs. You still have the final say, of course. Yet we feel it our duty to give you the facts.
Like you, I will put a minimal windshield on in a minor effort to reduce the amount of force I have to resist. My F3S has just a very small wedge on the front to protect the instrument panel. It looks cool but it gives me zero protection.
On my trip to Springfield last year it was pretty brutal doing 75-80 mph for 11 hours each way. A fair amount having been done into a stiff headwind at times. I will improve wind protection on that bike before I take it on another extended, high-speed trip. Still, I will look for the minimum I can get away with. Because when I ride, I enjoy the wind.
