Will upgrading the Sway Bar and fitting larger tires improve the ride?
You have to be careful on the 2020+ on front fender clearance. Improve the ride? It does improve handling and semi's will not blow you around as much. Better in the tweezes.
On my 24 RTL I added both front shocks and an upgraded sway bar (I still have the OEM tires with only 1400 miles on them) and the ride was immediately better for both me and the wife. The Sway bar upgrade will help mostly with cornering, while the shocks also handle road roughness.
