Did that raise it up 3/4 inch? That would be nice, as both of my S2S's (2023, 2024) don't have much clearance.Due to the cost of most performance shocks, I purchased Baja Ron's anti-swaybar and the Quatrac tires first and that was an amazing change within itself.
Once I saved up the money, I purchased front and back Wilbers shocks next and got an alignment because it changed the ride height by about 3/4 of an inch, that took it to a whole new level.
Did you raise it? Or did you simply bring it back to recommended ride height? (Which is what we recommend.)Due to the cost of most performance shocks, I purchased Baja Ron's anti-swaybar and the Quatrac tires first and that was an amazing change within itself.
To improve cornering stability on the 2011 Spyder RT, where should I invest first - shock absorbers, or a stabilizer bar?
If there were better roads, the OEM shocks and sway bars might be more than adequate.Sorry Gwolf, how did this comment answer this guy's question? I am down in the weeds tiring to find it.![]()
I'll go measure it again, but if I remember right, I went from about 3 3/4" to almost 4 1/2" measured at the front skid. But I am getting ready to change over from the Quatrac 165/60/15 to the 175/55/15, so that may change again. Never intended on changing it, but when I went from stock to the Wilbers shocks it came up. I measured it at the same point before and after I installed the Wilbers.Did you raise it? Or did you simply bring it back to recommended ride height? (Which is what we recommend.)
You should be between 3.5" & 4" from the ground to the front of the large, rectangular main frame member running along the center of the bike. This height should be achieved when loaded in your standard riding configuration. Typical passenger(s), storage, etc. You'll need a helper to do the measurement since you will be sitting on the bike. We also recommend a setting closer to the 4" measurement.
Your bike will settle a little differently each time you mount it. So it's not critical to get it just right.
With upgraded shocks, you are not only able to regain lost ride height, but you will also reduce dive over speed bumps, steep driveway approaches, and other situations which, on a stock setup, can cause your front end to strike the ground.
You would be surprised at how much ground clearance you lose when loaded with the stock setup. Why BRP does not include spring preload adjustment on all Spyders, like they did for the 1st 5 years of production, is beyond me.
Added Note: For a 2011, aftermarket shocks are not the only option (though they are probably the best). But you can get a great deal of improvement for a lot less money from installing late model RT shocks on your 2011 RT. I recommend 2018 and above. But even the 2014's and later will make a noticable difference. You can find good take off shocks on eBay. And some repair shops have them as well.
I just switched to Baja Ron’s Ultra sway bar in July. The difference was noticeable at the first corner. The factory bar had gaps & was worn shiny at the support blocks after 20 K kilometers. Wished I had done it sooner.To improve cornering stability on the 2011 Spyder RT, where should I invest first - shock absorbers, or a stabilizer bar?
