Windscreen rattle - is this an easy fix?
NorwegianRT
On my RT I get some rattle from the windscreen when hitting some bumps in the road.
I have changed the arm coming from the windscreen motor to a solid one, but I think the rattle comes from the two other swingarms for the windscreen, as there is some play when I wiggle the screen by hand.
Do I need some new rubber/plastic bits to silence them?
The rattle is coming from these arms, I think.
I had the same issue on my factory F3T lowboy. When I installed a new GP Cycleworks windshield, it went away. I believe the rubber washers were the culprit. The old washers basically fell apart when removing them.
Thank you all that gave tips.
I will take the windshield off and check the rubber bushings and see if I can replace them.
If I fix it I will come back with a new reply here. 👍
I changed the arm on my 2012 and found that the screws on those side arms would loosen up and back out after time and I would tighten them every now and then. I had such a time getting them out because of the size of the screws and that darn yellow goop they use that I didn't replace them with anything on them, maybe I should have but I didn't want to deal with thread locker if I had to work on it again.
