Cruzr Joe
Bugs, Dirt and whatever else that can get in there did, i am talking about the area behind the windshield, it is raining outside and i am bored so i looked up on spyderlovers.com and found how to remove the windshield, the instructions are below, it was easy and now that area is clean. Thanks to gadgetguy442. The trim takes a T25 the other is a T30.
The windshield trim plates are held in place with a single torx head screw (sorry for the blurry picture). Once you remove the screw, slide the trim plate straight down while you gently pull the upper half of the plate forward, away from the windshield. This will allow the "L" feature at the bottom of the trim plate to release from the cutout in the windshield. Take your time here, as you don't want to impart any scratches to your windshield!
Once the trim plates are off, you'll see 4 torx head screws that secure the windshield to the support. Remove these and the windshield is free to be removed and cleaned. You can also clean the support and other areas of the cockpit that are normally inaccessable.
Re-installation is straightforward and done in reverse of what's described above. Tighten them until they seat fully on the steel bushing within the rubber isolators. When installing the trim plate, hook the lower attachment "L" first, slid up gently (holding the upper attachment away from the windshield so you don't scrape it), until it's up high enough that the upper attachment can set into the cutout recess in the windshield. Install the trim screw and you're work is complete!
Bill
Bill
