2014 RT Limited Struggling on Starting, then the display goes to vertical lines! Could this be the battery going bad already?
94gnatsum
2014 RTL with a 2 year old battery. Always on battery tender when not riding. Here's my issue, when I turn the key on everything occurs as usual. you hear the fuel pressure etc, the warning comes up on the display, cycle through that, go to start, the first revolution seems to struggle. the display goes to vertical lines. After 1/2 second she starts up and runs find but I notice the pre start warning is back on my display.
Again, the bike runs great, shifts great. Clock seems to to be keeping up. My only recent mod, in the Spring, was a set of LED headlight bulbs from LaMonster garage.
Could this be the battery going bad already? Starter going bad? Got, I hope it's not a computer issue. Are the LEDs causing the start up issue?
I'm hoping someone has seen/had this issue before.
Vertical lines and the recycle of the display = voltage issue. The struggle of the first revolution pulls the voltage down. What kind of battery, how many CCA, was it properly charged during activation, etc, all play a role in that a 2 year old battery can fail prematurely. You might be able to save it with a full charge on a charger, not just a tender. Clean and tighten the terminal connections. You might consider a load test of it, but it sounds pretty straight forward.
Like Snowbelt said this web site is full of posts just like yours and it is just about straight forward, your battery needs to be replaced! Get one that has at least 350cca's, make sure it's at full charge before you put it in, and if you're the type of person who rides every week for a good ride, do your battery and yourself a favor and stop putting it on the tender ALL the time! If you are going to leave it and not ride it for months at a time then sure, use one! If you do that, then you have a better picture of what's going on with your battery. Some people that do what you have done get their bike started, go down to the local gas station to fill up, shut their bike off, and then after filling, find it will not start again! When you see/notice your bike rolling over slower than normal at start up, it's trying to tell you something!!! If nothing else, clean your battery posts, put lock washer on the bolts, have it load tested, it will probably fail!! Good luck!
My original battery began heading south in the fall, 2019. It began cranking slower but I had a Rugged Geek lithium jump start pack (actually had two of them but that's another tale) and one day running an errand it died in Wally World parking lot. The last thing that happened on the dash screen was it flashed a bunch of vertical lines, and then nothing, dead! The Rugged Geek got the bike started and returned home, jumped in the cage and went for another Yuasa battery.
Thanks for the thoughts, I assumed it was the battery. My first battery lasted about 7-8 years, this one 2. When I bought the Spyder, the tech told me to always put it on the tender when not riding. Sometimes, I go 3 weeks between rides because of work, sometimes 1 day.
Again, appreciate the responses.
Well, just a final note to you. The word Battery "tender" gets thrown around a lot and is fairly general in nature. But specifically, you can get a basic tender, that simply keeps a constant float charge on the battery. That type will typically kill a battery. Or, you can get a battery "maintainer", which actually cycles the battery through charges and discharges, all automatically, and minimizes battery sulfation. You can use those units almost continuously because they help maintain battery health. You get what you pay for. 20 bucks or 80 bucks. You might find one of these to be a good investment, as well as others:
Also, a battery tender can also go bad and over charge the battery and kill it. Years ago I had this happen to me. It was a trickle charger/tender and it failed to shut off when charged and cooked the battery. So even with the best intentions, it can go south on you.
New member here, but been riding over 50 years and am a part-time cheap mechanic at a local independent shop. Batteries can be odd creatures. I've seen the best, brand name batteries go FUBAR inside of six months, and cheap Walmart batteries last 6-7 years. For some reason it appears to be happening more often. Some batteries have only a 6-month warranty, others up to 2 years. Get what you think will do the job, and then get a Deltran Battery Tender, or similar. Not the 1-amp trickle charger that can cause the battery to boil dry by never shutting off.
A couple of things you never want to do, walk across the street against a red light, and cheap out on buying a battery. Always get a quality battery from a business that sells a lot of high-end batteries. You'll likely get a fresh one, because batteries that sit on the shelf can go stale and they don't get tested before they sell. Load test your battery and see if it's up to doing the job you bought it for. And purchase a quality tender also, but only use it for long term storage. Wish you good luck.
On mine, I would get a low voltage warning on start up. I tightened the battery terminals and the issue was fixed.
I disagree with the tech, if you ride frequently, keeping your ride on a battery tender is not necessary. To date I have not had a battery issue. Here is my story:
I used to keep my rides on a battery tender whenever she was resting. Since 2023, I live where I must park outside with no access to electricity. From April to December, when resting, my ride is not on a tender. I ride several times a week, so there is no need. However, from December to April, with the potential for terrible weather, I keep her in a storage unit attached to a battery tender powered by a battery-operated generator. I recharge the generator every other day so my baby is on the tender 2 to 3 days a week. Again, no battery issues.
I have a 2021 RTL and a 2016 F3L. I had to replace both batteries this past Spring. Both were ridden about the same amount and rarely put on the maintainer. The 2016 just simply had a better battery.
There's a LOT of Spyder Owners out there finding out the same thing, and coming to the same conclusion. :rolleyes:
I have a 2017 RT SE6, bought new. I have experienced similar to yours, but only when the temperature drops below 45°F. I put it out on Spyder lovers, and hardly anyone else had the problem I described. Even those that live up in Canada, were not having this problem. One person suggested giving several short burst attempted starts. This has worked for me, after trying 3 to 6 very short attempts, the bike would start. Since new I haven't done anything to the engine, other than my annual oil, and filters changed. As of now, I have just over 20,000 miles on the bike. I have changed out only the starter relay, found in the left fuse box in the frunk. It may have helped, but not sure. Other than this, the bike runs absolutely awesome. This is my 6th bike, after over 43 years on 2 wheels. This one is definitely a keeper. Now 84 years young and still riding. Hey, y'all ENJOY!!! Up here in Northern Connecticut, getting about ready to put the bike up for the Winter. Just before the State starts to treat the roads with that nasty stuff.
