2018 RT sporadic upshift issue - any suggestions?
bluey rt ltd
Hi, my 2018 RT Ltd has a sporadic upshift issue, i.e. sometimes I cannot engage First gear or sometimes shift up from say First to Second and so on. It will run fine for months on end, then come back to haunt me. Reverse is no issue; Neutral, when the engine is switched on is ok; but try to engage First gear, nothing happens! I have checked, the brake is engaged and lights up in rear. I have tried manually under the left foot rest as well. As I said it is sporadic. Any suggestion would be appreciated. I have cleaned the left controller as well.
How is your battery? When I had a 2011 RT, it started acting up on shifting. It was a weak battery that caused the problem.
Good question. I just went to start it where I left it yesterday and upshifting was fine. Now I have the bike home I put it on the charger.
Rode to get a new battery, after a brief charge managed 3km, then went into limp mode, but got a new battery installed. Had the original Yuasa, which must have been 8yo I would say. I am the second owner. Wow, what a difference it has made. Cranks so much better and no shift issues. Well, at least not yet, anyway. I have to say, I'm new to the Spyder world as of last year, after having a stroke, so I did not know what was normal when cranking. I put it down to Spyder quirks. Thanks to all for the suggestions. Glad to be part of the community. I Reside in Tasmania, Australia
I apologize for not mentioning this possibility in my original reply. Though we have found a good number of Spyders with cluster issues. The battery is almost always the 1st place to look for any electrical problems on the Spyder.
Yup, with these bikes if you have anything electrical going on, you've got to load test the battery first over anything! How many people on here have come to the site and said the battery's new, it's got to be OK, then it's been the last thing they checked the right way and guess what, it wasn't!! You have to love computers!!! :rolleyes:
Damn upshift issue is back. Thinking still battery issue though. the guy who activated it yesterday certainly did not seem long enough for the sulfate to penetrate the lead and certainly not long enough to charge. I Should have known better myself to get it home on the charge overnight. But live and learn I guess.
I hope it does end up being the battery. With a BS (add the acid at sale), it needs to soak for about 20 minutes before charge is applied. Then a low amp (around 2 Amps on a motorcycle battery) should be applied for about 10 hours to do it right. You can run a higher amperage for less time, but it's best to do a slow initial charge over a longer time.
I hope so too, fingers crossed
