Anyone else's Multi function switch not working like this?
Donbmw
2010 RT SM5. Out for a ride stop for a break. Went to start the bike, but when touching the mode button, the safety message would not go away. After many tries, the message didn’t display and I was able to start up and get home. At home, trying to start got the message screen again. When I tried to start today, the safety message didn’t display and I was able to start. While letting the Engine run, I found the following. The Mode button does not cycle through all the different modes; the turn signals are not working; the headlights are on, but won’t go to high beam or flash; the trans will not go into reverse; and the up, down, left, and right buttons are not working also. Anyone else experience this?
I can't say that I've had this happen to me or that I've come across it before, so this might not be of any help at all and I could well be wrong, but I do have a vague recollection of this being reported here before (a fair while ago??) and the fix being replacing either a dud fuse &/or relay, altho I can't recall which/which one?? (Bleedin' over-active forgettory! 😖)
Still, it might be worth your while to try checking the fuses and relays while you wait to see what everyone else can offer. Good Luck! (y)
