Anyone else's Multi function switch not working like this?
Donbmw
2010 RT SM5. Out for a ride stop for a break. Went to start the bike, but when touching the mode button, the safety message would not go away. After many tries, the message didn’t display and I was able to start up and get home. At home, trying to start got the message screen again. When I tried to start today, the safety message didn’t display and I was able to start. While letting the Engine run, I found the following. The Mode button does not cycle through all the different modes; the turn signals are not working; the headlights are on, but won’t go to high beam or flash; the trans will not go into reverse; and the up, down, left, and right buttons are not working also. Anyone else experience this?
I can't say that I've had this happen to me or that I've come across it before, so this might not be of any help at all and I could well be wrong, but I do have a vague recollection of this being reported here before (a fair while ago??) and the fix being replacing either a dud fuse &/or relay, altho I can't recall which/which one?? (Bleedin' over-active forgettory! 😖)
Still, it might be worth your while to try checking the fuses and relays while you wait to see what everyone else can offer. Good Luck! (y)
If you have all of your functions not working you may want to look really close at the wires going out of that switch for broken wires, or rodent damage under the covers! It may be the switch itself but theirs more than one switch under that cover that control's your problems you are having. I hate electrical gremlins! Good Luck
