Baja Ron's new Ultra Sway bar is great! Easier to install, too!
I picked up the sway bar when I was ordering stuff from Lamonster. There was no other sway bar listed.
Fortunately my brother was a mechanic for years, so he's got a really big floor jack and very tall jack stands.
I've been lazy in getting this done, I had a friends trailer lined up to use the ramps but he ended up moving.
now I'm hosed on how to get this done, I wonder if I can return it.
It would be a shame to miss out. Maybe wait and see if the new neighbor can help? :joke:
But if you purchased from us. Yes, of course it can be returned.
I really like this method. Highly recommended if you can pull it off. I even had a customer go down the street to a neighbor and ask, knowing they had this equipment. It's worth a try!
One of the keys with this method is ramp spacing, you need to have your wheels positioned as close to the inside of the ramps as safely possible in order to access everything. If your wheels are on the outside of the ramps you will not have enough room to maneuver even if you have the proper height.
And remember to take your tailgate off so you do not damage the hinges.
I bought from another vendor. I'll get it sold locally, then use a cut off wheel to get to old one out.
Or use a Tundra for your pick Up. Loaded Our Polaris Ranger many times. Ranger with me in it weighs well over 1,000 Lbs.
However, I do recommend Jack Stands as a safety measure when you get under the vehicle.
I just installed a new Ultra Bar on our 2022 RTL. It was fairly straight forward and easy to accomplish. The entire job was about 2.5 hours. Now I need the weather to warm up so we can try it out.
Thanks Ron for a much needed product.
It's usually listed on Baja Ron's Facebook "store"
https://www.facebook.com/profile.php?id=100057310845203
or easier yet, just call Ron's shop (423) 609-7588 - they'll hook you up. I put the ultra-bar on my '18 (I'm a 260lb driver) and still had to add his front shock pre-load adjusters but the combination has been fantastic. I also used a $100 Harbor Freight or Northern tools ATV jack and a large block of wood to lift my Spyder (and others) high enough to R&R the swaybar. Easy peasy.
Maybe I'm blind but I don't find the link to the Ultra Sway bar for 2023 RT on Bararon Sponsor page :dontknow:
You are correct and I apologize. Demand for the Ultra-Bar has kept our fabricator very busy. We have them in stock, but I have not put them on the Home Page Banner Ad site yet because keeping them in stock has been Nip & Tuck. (When's the last time you heard that one?!)
I will probably be putting them on that page later this month. Once I have a comfortable supply on the shelf.
You can always call the shop at 423-609-7588. We are having some phone trouble with our provider and the answer message is not currently working. So, if you get that, it means both lines are busy. You can try back or email at fyredad@hotmail.com
We are 8-5, M-F, Eastern Time Zone.
We are 8-5, M-F
Already added on the Sponsor page!
Nice work Ron :)
My Ultra Bar and the shock adjusters should be arriving tomorrow. I'll be installing them this weekend (I hope). I'll take some pictures and post my riding impressions this weekend or early next week.
Put an Ultra bar on a couple days ago and really happy with what it has done to the suspension. When my shocks come in it'll be a beast.
Question though: The instructions mentioned thin and thick spacers for the end links - but my BajaRon end links only had 8 identically sized spacers. Case of outdated instructions or what? The thin spacers seem to be working fine and the end links didn't seem to bind anywhere.
The 2008-2012 Spyders take thin and thick spacers which have a specific orientation. 2013+ Spyders take all thin spacers. Some of my vendors supply their own instructions. That may be what you ran into.
Today I installed my new Ultra Sway Bar that I ordered from Spyder Pops for my new 2023 RT Sea To Sky. The install took me some time, but it went well otherwise. I had to lift the front end of the Spyder to get it up to the 24 inch clearance that I needed to remove the OEM sway bar. The way I did this was, lift it with my Kioti tractor bucket loader with the fork lift attachment. I lowered the forks at ground level on the garage floor. I then drove the Spyder onto the forks to the front of the loader bucket where the fork lift bracket attaches to the bucket loader. I started the tractor and carefully lifted the Spyder keeping the forks slightly angled up so the Spyder would stay positioned to the front of the loader bucket. I made sure to lock the hydraulic control lever on the tractor and secured the loader bucket and the fork lift arms with jack stands. I also put wheels chocks on the rear tire for added safety. It looked a little scary at first, but it worked out very well. It sure made it easy to do the work needed under the Spyder to get the new sway bar installed. Once completed, I took the Spyder for a test ride and was very happy with the performance of the new Ultra Sway bar. It really is an improvement over the OEM sway bar for handling and control.
Baja Ron Ultra!
I will admit I was a little skeptical about the benefits of a new sway bar. I have a 22 F3L and often ride with a buddy that has a ‘15 RT. When he’s following me he remarks about how much less lean my bike seems to have compared to his. So I thought I had it pretty good.
But, after reading a lot of posts here, I decided to try the Ultra bar based on our 2-up usage (and the combined weight 😏 ). After just one day all I can say is WOW!
Somebody on here said this should be the first upgrade anyone makes.
Amen! It’ll be some of the best money you’ll spend.
