Did you use a ring compressor?
No.. this is the first time I ever putting a piston in a cylinder and learned my lesson.
The rear cylinder is back on, all the gears are back on, clutch reassembled and back on. The front cylinder is locked at TDC and just waiting for the rings to show up tomorrow. I am going to put the rest of the gears back on the magneto side today and the fly wheel will be going back on today too. Oh yes and I did replaced the broken needle bearing in the clutch and pack it with bearing oil. :thumbup:
Just couple of points.
*I did left the clutch cover off to help located TDC for both cylinder. You can see TDC coming up by looking at the crank or the cam loop. You can also double check by watching it coming up from the clutch side. On the clutch side with the cover off there is an opening in the crankcase. I can see the bolt hole in the mag swing by. When it line up with the bolt hole on the crankcase then slide your locking bolt in and lock it. The crank will not move and you are on TDC. You can double check the cam loop and valves on top.
*I shined a small flash light into the bolt hole on the crank case to line things up. EASY WAY.
*I also did it by feel. If you thread the locking bolt in until it hit the mag then back off just a hair. While TDC is coming up then just try to thread the bolt in slow and easy as you turn the crank. The locking bolt will go into the bolt hole eventually and the crank will lock. This will be useful if the engine is on the bike and all the covers is on.
*The Dow Corning oil is almost like a Vaseline paste.
I will try to load a picture of it later but internet very slow lately.
Thanks.. stressful but had fun. Like always any tips, tricks and I must know please send it this way.
