jthornton
Just reading the service manual this morning and like skeetshooter did the bleeding sequence is:
Left Front
Right Front
Rear
VCM
They have you do all kinds of things and some I don't understand and some make sense:
remove front wheels
remove the calipers and position bleeder at highest point
detach lift cylinder and passenger switch from seat
unplug low pressure switch connector and brake light connector
detach brake fluid reservoir and move to outside the footrest
Ah here is the note: the previous steps are required for the hoses to run completely down toward the master cylinder.
Then they go into installing clear hose on bleeder valves and bleeding the brakes...
JT
Left Front
Right Front
Rear
VCM
remove front wheels
JT
