Can the Passenger Back Rest on a 2025 S2S be moved forward a few inches? Not the whole trunk, just the backrest...
Good evening all,
Gave up looking for used Spyder Limiteds that still have BRP warranty and spent the day at my dealer going on Demo ride on a 2020 RT.
We have a 2025 Sea to Sky in the works that we are close to closing the deal on, but Mamma Bear asked a question that sales or service could not answer…
Don’t shoot the messenger but, is it possible to MOVE the rear passenger backrest forward a few inches? Not the whole rear trunk just the actual backrest...
I looked into the rear compartment and did not see a way to separate the backrest from the actual compartment, and the dealer wasn’t open to me taking it apart in the showroom for some reason ;)
Thanks for you input
Nutin
2025 S2S on the horizon, *CROSSING FINGERS*
Inside the top case there are two #20 torx screws on the front of the case on either side of the top case removal tool holder. After removing them you should be able to remove the passenger backrest. I'm not sure that you will be accomplish anything though. You may have better luck just adding a foam pad to the face of the backrest. Good luck.
Thank you very much, if the problem is there after a few hundred miles for Mamma Bear will dive deeper into it. Hopefully after passenger arm rests, it won’t be an issue.
Nutin
2025 Spyder S2S *pending pickup*
I don't think it would be hard to remove backrest and take to an upholstery shop and get it recovered with extra foam. Good luck.
Leon
Nutin
Mama bear afraid of falling off? Those OEM arm rests with an OEM drivers backrest will keep her placed in there like a baby in a highchair!
That is for sure. My buddy did an SS1000 with his wife on the back. She fell asleep in short order and woke hours later to ask why her feet were wet. They had ridden through a rain storm and she didn't realize it. That is what I call a 'ride or die' chick, but she stayed on and didn't waver.
Nutin
I don't know what your backrest looks like, but if it is like mine, you can remove the torx screws that hold it to the top case, put in a cut to fit piece of 2x4 between the back and the case, get 2 longer screws at a hardware store to secure it all together again, and be good to go. I will leave it to your imagination as to what to cover the gap with.
I agree with the recommendations to remove the backrest and take it to an automotive upholsterer. We did just that and came away with a "custom" backrest that now has lumbar support. Since this was a professional shop, they were able to completely reshape the padding and reuse the original vinyl cover, so it looks totally stock. I believe we paid about $60, and it was done in about a day.
