Can the Recall Update be UNDONE?
Batmobile
Can it be set back to default settings or once its done its done, unless they install it again?
I was so happy with my spyder before I had it done. I even thought about not doing it, but I thought better safe than sorry. Now I am SORRY!:(
The handling was great, it ran smooth at lower rpm, and pulled hard from 4K rpm up in any gear. Now it surges trying to hold a constant speed, check engine light comes on from time to time with "CHECK DPS" scrolling with no powersteering, high speed cornering the steering is too sensitive, and acceleration isn't what it was. Before if you were cruising in 5th gear at 65 or 70 and came up behind someone driving say 55. If you let off and coasted down to there speed until it was clear to pass, you could stay in 5th blip the throttle and be gone. Now you have to down shift because it won't pull hard unless you are above 5k rpm. It just seems more sluggish, maybe they did flatten out the curve to help gas mileage. I liked the performance, maybe the fuel update could have been optional. Also if I turn on the JB, even at half the numbers we were using, it pops and backfires on decel.:gaah:So it's pretty much useless for me now.
Ok. Sorry, rant over.
I just miss the good ol days:pray:
Thanks, Chris
Thanks, Chris
No way will they -'undo' this update. You need to go see your dealer and have them fix the problems. It seems there may be a relationship between those using the juice box and this update causing problems.
Regardless of the update - I wouldn't even think of being in 5th gear under 5,000 rpms - this rotax likes to run higher rpms. I don't even think about 5th gear until 65-70 mph--- heck you can hit 63 mph in 1st gear!
Sorry you're having problems - but I think you need to yank the juice box - have the update done again and see what your dealer says.
I would not dissuade people from getting this update done as it solves some dangerous steering problems.
I wasn't trying to get people not to do it. I just wanted to know if it could be undone. They downloaded it twice at the dealer because of the issues with the check engine light and code.
Now I have serious steering problems and I didn't before.
I know it likes higher rpms but it had the balls to pull it off before and now its flat in that range between 4k and 5k
The steering used to get tighter at higher speeds so you could make small changes in high speed turns, now its so sensitive any pressure on the bars and it moves all over the place.
I know this is all with my spyder and others have had the update done successfully and are happy.
I just wanted to know if it was possible after the update for them to reset back to the default settings and maybe at least start from there.:dontknow: Since it was running flawless until then.
up grade
Thanks, Chris
Don't give up yet---I had a problem with mine that showed up when I was 300 miles from home.:yikes: The problems I was having wasn't as severe as yours; However, mine was sputtering, popping, missing and generally running terrible; Especially at low speeds.
That has been about 700 miles ago and now the thing runs better than it ever has.The only thing I did was trim down the NO. 2 mode on the JB a couple of settings and drive the hell out of it for about 300 miles. I guess the computer corrected itself.:dontknow: I never noticed much, if any difference in the steering, never had a complaint with that.nojoke:doorag:
Had the steering download done today. My Spyder went from a smooth running, sharp accelerating machine to a dog! Surging, significant drop in acceleration and just not much fun to ride. I had huge reservations about getting it done, but felt that the potential danger of faulty steering outweighed that. Very sorry I did it now. Will take it back to the dealer, but if this can't be fixed , I am afraid I will let her go and get something else. Having had such great performance, I cannot ever be satisfied with the anemic machine I have now.
I've thought about selling mine, was thinging about getting another, but I know I wouldn't buy one that runs like mine does. and doubt that anyone else would either. So unless BRP comes up with a fix, I guess I'm stuck with a useless piece of JUNK.
Boy did I get wordy - emotional subjects do that to me
How can we be really sure that this software update solves "dangerous steering problem/potential."
No one knew there was a steering issue until some people reported it and some have incurred an accident because of it.
My view, until this first recall update is fully successful for all vehicles in the field and no reported steering failures over a period of time (months)-who knows :dontknow:
BRP engineers and software quality control eingeers think so, but more than a few stock Spyders don't seem to like this update. Easy enough to disable power assisted steering until the smoke clears - Spyder is quite enjoyable and more dependable without it. Several people didn't even realize that they didn't have it for quite some time.
I'm not sure my dealer did the update when I got in for my 3000 miles service a few weeks ago. Now I have to take it in for the 6000 miles service and am not sure I want to have it done.
Making me nervous.
No way will they -'undo' this update. You need to go see your dealer and have them fix the problems. It seems there may be a relationship between those using the juice box and this update causing problems. Not so sure about the JB causing a problem...in fact, it can likely fix a problem as it's the only way a person can affect the fuel should the update be off a little...I am going in this weekend and will shut off the JB...when the update is done, I'll reboot the computer...disconnect the battery for a while...reconnect, idle for 15 minutes, shut off again...and then give it a go...hopefully all will be fine...I'll play with the JB later to tweak things...
Agreed...steering fix can save your life...some rough riding can be corrected...
No Change in Performance - or steering
Both of ours have been done - no noticeable change in performance:2thumbs:
Mine has been at a second dealership for a week now. They are getting a new DPS unit to hopefully solve the periodic check engine light and scrolling "CHECK DPS". After the tech drove it he called me to tell me what he thought and I quote, " Your bike runs like a piece of s**t!". Which I totally agree. With it running a little hotter now and surging worse the hotter it is, it really can't be driven here in southern Texas with the heat and humidity we have right now.
So they will try and fix one problem at a time.:sour:
I definitely agree with others about calling BRP customer support and having them document your problems and when you had the update done. One number is on their website and another one is on the recall letters. You can also email them at spydertech@brp.com. Just have your vin # handy and they can pull up all of your info. I even got a call back this week to see how things were going.:D So I think they are trying.
Some of these issues should be posted in the Spyderlovers forum. Lamonster has a poll running to gather data and send to BRP. He is very active in all aspects of the Spyder. Seems to have a huge knowledge base. Check it out. I am waiting to have the update done until more is heard from BRP. I have the Evoluzione high flow air filter, O2 modifier and a Leo Vince exhaust. It runs great! Stronger and smoother than stock. Throttle is much more drivable. Stock, the throttle seemed very touchy, not any more. I would be very irritated if I lost everything I gained with the upgraded parts. Guess time will tell. I hope BRP addresses these DPS update problem promptly. :dontknow:
Had update done
My previous post spoke of how unhappy I was with the download. To my great suprise, the Spyder continues to run better and better with every passing mile. The hesitation is practically gone, but the crisp acceleration has not completely returned as yet. It still runs a bit hotter than before and I think it is a bit lean. Will report further as the miles pile up.
I confirmed today that my local service dept will NOT return the software back to pre-steering-update status. I've stopped ryding it altogether, feels like the engine is starving at mid-RPM, can't be healthy. I'm also waiting for a reply to my email to Spyder Tech Support.
Have you tried pinching closed the hose from the purge valve to the throttle body? On some Spyders a stuck open purge valve is making the machine run really lean. If it runs better with the hose pinched then you've found your problem. If not at least that's one problem you don't have.
It would be nice if we could confirm if it is running lean or rich. Some say they leaned out the JB settings and problem solved. I removed the quiet core from my exhaust and problem is slightly better. This should have leaned out the mixture. I have the o2 modifier so I can't imagine it is running lean.
TALK TO A DEALERSHIP ABOUT THIS ON GOING PROBLEM.. THEY TOLD ME THAT ON TUESDAY 25AUG2009 BRP IS GOING TO BE DOING A WEBCAST WITH THE DEALERSHIPS ABOUT THIS PROBLEM SO HOPEFULLY WE WILL HAVE A ANSWER TO ALL THIS :cus:............:2excited:
I had a discussion with the service manager at my dealership today and asked him if they have been getting owners complaining that the update caused the Spyder to run worse. He said that they personally haven't been getting complaints but he's seen the online talk of Spyders not running right after the update. He told me he thought it was an issue with the dealership doing the update correctly. There is more to be done above plugging into BUDS, accepting a few questions or prompts in a text box, and then unplugging the Spyder. Like widowmaker2011 stated in a previous post, there are other components that need to be reset or re-zeroed (like the TPS) for everything to work right. If the tech misses those steps, the computer is now using invalid data about throttle position, steering angle, yaw, etc. when trying to determine how much fuel to give to the engine or whether the VSS needs to intervene.
Probably those that have had a great running Spyder since doing the update had a tech who did the update 100% correctly. Those who've had issues probably had a tech that didn't pay attention to the full update instructions so they don't know that there is more to the update (but they think they know and think they did it correctly).
Brian- agree almost 100% , however the full update instructions don't mention didley squat about tps reset and gps reset.... if the dealer follows the update instructions it isn't mentioned. So far from what I've seen the techs that have a working knowledge of the Spyder are catching this through experience, techs that are just following the bulletin are missing it due to it not being in the bulletin. Wake up BRP. Please.
