Canyon Front Tires Rubbing the Fenders
greer
Well-known member
Several of us on the Canyon Lovers FB group reported hearing something that sounded like the tire rubbing the front fenders when hitting a bump of some kind while in a turn, such as turning into a driveway or a parking lot. I took my front wheels off to have a look yesterday, and sure enough, there it was.
These plastic fenders have a good amount of flex in the front, just enough to let them flop down and make contact. It’s not as easy to see on the one fender but you can feel the dip. I’ll let BRP know, I suppose I’ll start with the sales guy I bought from and go from there.
Sarah
My Canyon makes a creaking or popping noise when turning and going through a dip (such as when turning into or from an elevated fuel station. My perception is that it is due to flex of the water deflector in front of the pegs where it is attached to the tubular frame. I took it to my dealer and the tech drove it and he suggested the water deflector. I have not removed the wheel to look for scuffing under the fender.
I wonder if you put a dab of white paint on the scuffed area and drove it, if the paint would get wiped off? That would show if it is a current thing, or a past issue.
It's a current issue. I heard the right fender hit on my last ride, came straight in and pulled the wheels off, that's the spot I'm pointing to. It will become less of an issue as the tires wear, I suppose. I called CC Powersports in Louisville yesterday and talked with the service manager, he made notes and scheduled my appointment for July 8th.
Sarah
I wonder if a person could shim the fender up a little with washers??? There were issues years back when guys were putting car tires on and had to shim out!! Good luck Sarah!!
Thanks Mikey, I was wondering too, but I don’t know. Another couple of pictures I took the other day:
To show how the hangers are bolted to the bike:
It’s complicated 🤓 😄
Sarah
The mounts seem sturdy as can be, I think it’s the flexible plastic of the fender dipping down.
Just an idea off the wall, jack the rubbing wheel a little off the floor and spin it, checking the space between the tire and the floor, to see if your tire is out-of-round?
Stock tires at stock pressure of 20 psi. Both front fenders rub when making a turn combined with a bump, such as dropping down into a parking lot or driveway, which fender rubs depends on the circumstances. There's a good portion of the fender hanging in front of the brace, you can twist it this way and that with little effort. That's where the turn signals are mounted and it may be that their weight adds to the tendency to flex. Bear in mind these are the plain black plastic fenders like those on the Ryker.
Sarah
Okay, a guy on the Canyon Lovers FB group said his F3 has the fenders mounted the same way and he initially had the same problem. He was able to gain more clearance by loosening the mounting bolts on the wheel assembly and repositioning the bracket. I’m in Alabama to watch the Spyder Olympics at Woods and Water but I’ll be giving that a try just as soon as I get home. We’ll see how it goes.
Sarah
I loosened the fender bolts and pulled up on the front of the fenders as I tightened the bolts back down. A bit over 500 miles on the bike since I've made the adjustments, and I don't believe I've had the fenders rub. If they have, it would be the one case in which I made a quick turn and dropped hard into a parking lot, but the whole bike clunked such that I couldn't tell. Anyway, I've called the dealership and told them I want to cancel the fender inspection, but I'll still be there for the software update. I just decided I didn't want to foot the bill for nothing. Some folks on the Canyon Lovers FB group complaining about the fenders say they'll be reporting to the dealer, so maybe we'll get a chance to see how it turns out for them.
Sarah
I don’t know about the Canyon and the software updates you mention, but any software updates I have done myself through my home WiFi network.
That mechanism has taken my ‘26 Sea to Sky to release V 5.1.0. The only thing I would mention when doing it is to keep your vehicle on the battery maintainer to ensure full voltage, and to be patient as the screen turns blank for 20 seconds or so at various times. No, it hasn’t died, and it will continue after a while.
I think I misspoke when I called it a software update. It's an update for the Vehicle Stability System, but I don't know any of the particulars. Some owners got a letter from BRP, I haven't so far, but the dealer said my bike is listed as needing it so I'm heading there tomorrow.
Sarah
Ya, that fender issue seems to me that they don't have the bends on the mounting bars that run from the bike to the fender bent in the right way, a little tweak up and down in the right spots would give you more clearance! They are trying to leave a low clearance fit, too tight for my liking!!! You should not have to fight to get your tire up and on your Lugnuts. Not to mention if you were riding with Peter down under, you wouldn't want any items getting rolled up under there unexpected! :cool: Good luck, hope you got it!!!
Ya, that fender issue seems to me that they don't have the bends on the mounting bars that run from the bike to the fender bent in the right way, a little tweak up and down in the right spots would give you more clearance! They are trying to leave a low clearance fit, too tight for my liking!!! You should not have to fight to get your tire up and on your Lugnuts. Not to mention if you were riding with Peter down under, you wouldn't want any items getting rolled up under there unexpected! :cool:Good luck, hope you got it!!!
Been there, done that! 😖
And you've gotta stop immediately to clear it out - you can't just 'ride on' for too long, leaving what's left of the pesky critters jammed in there in the hope that it'll get dragged out sooner rather than later! Once they're mushed up a bit and caught up between a rotating wheel and the fender, the tire rotation starts to 'burn' them, and that very quickly STINKS!! :sick:
And if you're exposed to that smell for anything much more than just a few seconds, it seems to sorta permeate your nostrils AND everything you're wearing and then it takes a week or so to dissipate afterwards! (From your nostrils, too!) 🤬 Do you really need to ask me how I know this for a very uncomfortable, annoying (and smelly) fact?! :cautious:
Sarah
Ok, Sarah this may sound odd but I had the VSS update done on my Canyon and after that the self-canceling turn signals were no longer reliable. Sometimes after a turn the signals keep flashing other times they cancel fine. The reliability seems related to the force of the turn. Easy turn no cancel, fast turn, or turn with bump reliable cancel. After your update please report your results.
