KX5062
Well-known member
Recently there was another thread about the 30k miles requirement for replacing the air filter for the charcoal canister, part #709000524.
http://www.partshark.com/oemparts/a/cam/53f54766f870021dbc21b84f/fuel-system
Without really bothering to look at it I ordered the replacement, which was about $40 to my door. Once it arrived I was surprised at how simple it was, and how it had just 2 screws holding the halves together. Since it was a new part and I didn't want to risk damaging it I didn't investigate any further.
I pulled the original filter assembly and replaced it. I think Doc Humphreys has a video about it, but it's really super easily once you get the Tupperware off.
Anyway, that's not the purpose of my posting.
What I'm posting about is the fact that you don't need to buy a new one. It does separate in the middle. There is no glue or any permanent sealing. Just unscrew the 2 halves and you are left with a dry foam filter element melded to a metal support screen. Just take your air compressor and blow it clean and reassemble. Job done. BTW, it was filthy. The air intake tube is straight down toward the rear tire and belt area, so it gets a lot of dust and grime. Dust on the inside, grime on the outside.
So if you want, save yourself $40 (or so) and just clean it. There's no need to replace it. :2thumbs:
