IdahoMtnSpyder
Well-known member
Any idea when BRP changed to the later DESS module on the production line? My 2014 RT has a build date of 06/2014. The DESS has never given me a moment's fit.
Yes, those with earlier model years were fortunate not to need disabling the DESS as the DESS worked without fault. Can Am changed a system that worked fine in previous years to a few years of problems.
If you read the majority of this topic, 99.9% is focused on 2014 and later Spyders, and the person that started this topic does have a Spyder within that range of years.
PMK, do you know offhand if BUDS shows part numbers? My memory is such that I don't recall seeing, or not seeing, part numbers when I've had BUDS connected. Probably, in the length of time it's taken me to type this question, I could have gone out in the garage and plugged BUDS in and gotten the answer!![]()
At a guess, yours has the 710003140 DESS module. If Madison Sully could post the build date of his Spyder, it would let you know where yours falls in line. It seems that Madison Sully had the 3140 module from new, and your Spyder being a very late, almost a 2015, makes me think you have the 3140 also.
Our Spyder was kind of an earlier 2014, built in 01/2014 and is #1080. It had the first gen module when new.
My spyder VIN sticker has a DATE: 04/2014 noted on it.
My 2014 STS started throwing the DESS error and won’t start. Temporarily stranded yesterday, after multiple attempts over 20 min it eventually started. I swapped keys to my original spare (never used this key before) and the Spyder starts right up with no error. I’m looking for experience and advice on this issue please. Could I have a bad key, or bad ignition? Can this key be relearned / matched to the bike? Any help would be much appreciated. Thank you!
I changed the Antenna this past winter. So far no issues.
Hi, I have a 2013 STL. Lately I’m not able to start after pressing the mode button, and I need to wait for about 10secs before I'm then able to fire-up.
Now it doesn’t fire-up after waiting for about 10secs. I have to off/on the ignition then wait about 10secs to fire-up and sometimes have “BAD KEY” appear on screen.
Wonder will it work by changing the DESS antenna?
Do not know about your Model, the bulletin posted was for the 14 and 15 MY models. Have you tried another key for starters and check your battery terminals too?
