Do I really need to Change O-Rings at Every Oil Change? Do you?
I don't. Just changed them once in 50,000 miles. Just inspect them, look for any cuts, oil sludge build up. Watch taking them off over the threads. some have wrapped threads with blue tape I think. They do have important jobs keeping channels separate. They are a stepped drain bolt
As already mentioned, the answer is no. But it it highly recommended that you have a spare set of everything handy in case you find that a component is damaged. However, for what we spend on our Spyderderd, the price of a seal kit can save you some grief.
What he said, particularly with the sharp threads on the 1330 ACE engine OEM sump plug, the one needing a T45 Torx bit to remove.
Save yourself from a possible future headache, get rid of those frick'n OEM oil plugs. They may work for a while, but when one strips out, you're in for some real fun. Toss'm now and save yourself from the inevitable. And yes, I closely inspect the rubber o-rings, and if still good, I don't replace them. Otherwise, new ones go on.
