Almost forgot added the BRP 12v USB kit. I assumed this kit would have all the wiring required to make it plug and play which is why I paid the crazy amount they asked for it, but there is no wiring at all and still had to make a trip to Home Depot for the connectors. My advice to all those that are going to do this project, save the money and buy the plug adaptors from ebay or amazon for less than 10 bucks. The toughest part is finding the cable under the left service panel, it is covered in black tape and zip tied to a larger black cable.
FYI, the wiring for it, according to the instalation instructions is underneath the passenger's seat.
llyrad, how hard was it to do the Plasti-Dip? Did you remove panels or just tape them off?
Nothing fancy for this install (12v plug). Just grabbed a wood bit for the drill that was about the same size as the plug and spun out a hole for it. Although I did have to slowly enlarge it so plug would fit in nice and tight, as there is a rubber washer on it that allows it to be waterproof.
Still snow on the ground here in Northern Alberta, but we had a couple of nice days so I took the F3 into get the recall done for the shock support plate. And I figured while I'm here I upgraded the rear shock to the one designed for 2 up ($210 bucks = to about $170 of your US bucks ) much thicker spring and more coils, noticed a huge difference right away, it sits about the same height but is stiffer on the bumps and keeps it from bottoming out, and got the belt replaced. Now to find the time between snowfalls to get a 1000km on the bike (so it can be adjusted) before I leave for Spyderfest!
For the side panel portion (covering where the accessory headlights) I removed the full side panels and than you remove 2 screws and the grey pieces slide out. 4-5 coats of plasti dip- 30min drying time per layer. Let dry for a day (just to be sure and to let it cure) and put back together. Taking the side panels apart and using Plasti-dip are incredibly easy (and I am not that 'mechanically inclined).
As for the front grill "S" accent. Remove the 4 black screws from the front grill(outside accessible), to remove the whole grill, then there are 10 screws to remove from the removed grill and you have your accent piece, very very easy to do.
A couple little tips with Plasti-dip, you don't want to touch the pieces at all once you start spraying so I recommend using a stand like the one I made and make sure when you have 360' access to it (I had the stand on a table sitting in middle of garage), so you move around the object rather than moving the object itself. Doing it this way requires no taping at all. Just have the parts resting on the wood and your good to go.
If you need any more specifics shoot me a PM and I will help you out.
Sir, did you use any gloss with your plasti-dip work?
