Finally got Spyderpop's Bumpskid installed!
MakoShark2
Front of the Spyder was a little beat up mostly from going too fast over speed bumps.
I finally got Spyderpop's bumskid from Martin's shop (I'm located in Europe).
Instalation took a bit more of effort than as per instructions as I had to dismantle the grill, grill frame and some plastics covers under the Spyder.
I probably could got out without it but fitting the tight clips would sure be a challenge.
Drilling the holes were actually easy even the two at the back on the metal frames.
Lost around 3/8" (0.95cm) of ground clearance at the front so the it's hitting the ground a lot more only I won't worry now...
Might try to raise a bit the front shocks if that doesn't affect much the 4.5" (11.5cm) ground clearance at the front of the chassis.
