i have been out today testing maptunerx stage 2 flash on my f3s daytona with 79 tooth sprocket took about 15 minutes to install.tune only effects sport mode so its easy to switch between stock and stage 2 tune to compare. throttle response is more linear right up to the rev limiter no more bogging down above 6000 rpm and below 2500 rpm as soon as you enter sport mode you can hear the engine tone change after coming back from a 200 mile ride to let the ecu build the fuel tables i did 2 runs on the same road in different directions stock top speed on gps 125.6 mph maptunerx stage 2 top speed on gps 136.8 before i had to slow down for traffic i need to find a better clear police free road but there getting rare in these parts now. she was still pulling strong when i had to slow down so i think more testing is needed. very happy with the maptunerx tune plus i can read and clear error codes and reset ecu history if i need warranty work doing:yes:
Holy crap is the fan ever loud when running with Stage I
I have over 700 miles on the Monster Stage 2 flash and have not experienced the fans coming on any more than the pre flash configuration..
Zero negatives in my experience YRMV...
Very satisfied customer here..
I never even bothered with the stage 1 because I knew about the stage 2 coming..
I did not want to deal with the back and forth issues..
One stop shopping for me and for all marbles..
Again,,, Zero regret and the best bang for buck on any car,, motorcycle modification in 47 + years of doing it..
I have been testing flashes for Monster fuel since the beginning of this journey. I have two ECUs, stage 1 and 2.Both ECUs are dialed in and it's kind of cool that they are plug and play. It's really hard to tell which is which but here is two things that separate the flashes.
1. stage 1 has more instant starting power. from a dead stop, it breaks the wheel loose with straight throttle. It's hit and miss if stage 2 will break loose. I don't think this translates to a real staring advantage for either flash. But, I can tell them apart by starting power.
2. Mid range cruising around, mixed traffic, higher gears I can't tell any advantage or disadvantage between the flashes.
3. OK, things start to happen which are real nice in the upper rpm range with the stage 2 flash. It seems to start to separate from stage 1 around 6,800 rpm. But what it does really different for performance is how cleanly it pulls to red line. Stage 1 is flat going from 7,600 rpm to red line but stage 2 really shines in this area. To me it feels like 5 to 6 hp more in this area of the rpm range.
Dennis
Just my opinion from my testing. This is cold weather driving and Iv'e only heard the fan come on once.
maptunerx has a new stage 2 AGR tune available
What does AGR mean? Is a hardware change necessary? What does STAGE 2 bring to Horsepower?
Are ECU's interchangeable with other spyders? I read a post where someone had 2 ECU's, One with stage 1 and the other with stage 2.
As long as you have both/all ECU's programmed the same for all the other functions, it wouldn't be any different than if you had a replacement engine.
So lets say if I buy a second ECU and air filter cover, I could switch between tunes?
