Here's my ride height adjustable air shock!
exbrc1
AP1GczOx8pxdwfdmhCcMoFTc3yw6XAodtG2JQyPYLXdBph3iFUFLBsImemSK3lfoJw_WavBpwV8CxuZhmmDAPtozj0aNdP9zNTWKUHzW7EBTmyORBqjg5LfhD8TCO_XDi3V3wrfPvLxCY5N-Fqf2AmRfOPzx1g=w270-h360-s-no-gm
2018 RT Limited. $110.00 on ebay. The ride is the same as the stock shock, only now I can adjust the ride height.
I have to say that's thinking out of the box!! If you like the ride and handling great idea for you! You are right about being one step better than stock! 🙃
@BajaRon, so far I'm liking your shock adjustors on my stock front shocks, though I've not even tried different tensions since installing them. Lately all I do is work... and maybe ride to work lol though we did catch Deadwood last year, we left the day of the floods here in TX.
Sounds like you timed it just about right!
I measured the extended length of the stock shock and compressed length, then I looked up Monroe automotive shock specifications. They are 24 inches long. Also, I checked the diameter and upper and lower mounting type. I found one that was right, except the bolt bushing was about a 1/4 too wide. So all you have to do is use a grinder on all four sides and grind them just to the rubber, then they are the proper length. The hardest part of installing them was mounting them to the top mount on the frame, because the stock bolt was installed from the front so there was no room to remove the bolt and you have to take off the frunk. Then you can re-install the bolt from the rear.
do they stay set? no leakage? how many miles on them so far?
